Old 07-11-2010, 08:10 PM   #1
1972 27' Overlander
Hackett , Arkansas
Trouble shooting Univolt
We just purchased our first Airstream. It is a 72 27' Overlander. It is in very good condition. All the 120v works. The DC lights will not work when camper is connected to 110 power. I put a new battery in the camper and the lights come on.
I've checked all the fuses and they are good. I checked for voltage on the univolt there is no voltage. Early today I had voltage.
Is there a fuse/breaker box in the trailer? I can not find one.
We have the key to the door and it will not open the compartments, should we have a second key?
bhhogman is offline   Reply With Quote
Old 07-11-2010, 08:45 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
There is a power panel for the shore power. Mine is located in the closet in the bathroom. One of the branch circuits feeds the converter. Mine plugs into a standard 110 volt outlet which is located in the same closet, but under a shelf.
Richard
Old 07-12-2010, 09:20 PM   #3
1972 27' Overlander
Hackett , Arkansas
Thanks for the info, but I can not find a breaker pannel. I checked the closet in the bathroom. I have opened all cabinets and side compartments.
Old 07-12-2010, 09:55 PM   #4
1972 27' Overlander
Hackett , Arkansas
Found the breakers, they are not the problem. They were in the bathroom closet.
Old 07-12-2010, 10:48 PM   #5
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
I had a similar problem and traced it to a couple small glass fuses in the closet. There was a small fuse block and one of the fuses had come loose. Pushed the fuse back in and everything works. The fuse block on mine is by the wheel inside a cabinet.
ddstech is offline   Reply With Quote
Trouble shooting A/C-Heat zipman Furnaces, Heaters, Fireplaces & Air Conditioning 0 05-09-2010 08:09 PM
Solar Panel Trouble Shooting Help upstateart Winter Living 8 01-31-2010 07:13 PM
Trouble shooting 120V breaker box stanwilder Batteries, Univolts, Converters & Inverters 10 06-19-2009 02:08 AM
Trouble shooting 64 magic chef stove 59er Stoves, Ovens & Microwaves 4 08-28-2007 10:40 AM
Yamaha 2400is trouble shooting Boondocker Generators & Solar Power 29 06-17-2007 04:06 PM
