Old 09-28-2016, 10:11 AM   #1
2015 28' International
Ofallon , Missouri
Trimetric battery monitor install
This is part 2 of my battery box mod...
In part 1 I designed and installed a battery box extension to house bigger batteries and a shunt for the battery monitor. You can find the details here. The plans are available on the classifieds.
I have now completed part 2 which is the shunt install, wiring and the Trimetric monitor. Photo of the battery box with shunt and wires is attached. We have a 28' International, and the monitor fit very nicely right above the propane sensor below the couch cushion. It was relatively easy to route the wires alongside the current battery wire bundle, go up through the floor in the same hole, and then under the couch with no new drilling of holes except to mount the monitor. I tried to fish the wire through the current cable protector but was not able, so I plan to add wire protection.
mpsgolf is offline   Reply With Quote
Old 09-28-2016, 05:52 PM   #2
New Borockton , Alabama
Images: 21
Very nice. Great work there.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
Victron Battery Monitor Install NoResults Batteries, Univolts, Converters & Inverters 82 01-23-2017 10:02 AM
Battery Monitor versus Inverter Install Questions Searun Batteries, Univolts, Converters & Inverters 4 05-24-2016 01:34 PM
Help! How did you install your Trimetric? lsbrodsky Electrical - Systems, Generators, Batteries & Solar 20 08-14-2014 03:55 PM
xantrex linklite vs trimetric 2025A battery monitor demondeacon3 Batteries, Univolts, Converters & Inverters 8 03-17-2012 06:55 AM
New Trimetric RV Battery monitor 68 Overlander Commercial Listings 14 04-15-2009 11:14 PM
