Old 01-20-2015, 08:00 AM   #1
2014 23' FB Flying Cloud
Mill Valley , Left Coast
Trimetric 2030 Shunt location
I was thinking about mounting the shunt externally on the battery box in its own metal enclosure. I was also considering mounting a master battery disconnect switch here. Thoughts?
My thinking on this is the fact that I don't want something getting potentially red hot next to my battery. And for obvious reasons the disconnect switch.
J.B.
jbxx is offline   Reply With Quote
Old 01-20-2015, 08:17 AM   #2
1974 Argosy 20
Kooskia , Idaho
Look at the photos of what I did, post #18, this thread
http://www.airforums.com/forums/f449...-124829-2.html
The shunt will never get "red hot" unless you have some kind of a short.
It is hard to find a place for the shunt and an external disconnect switch near the battery box which is jammed in between the frame rails and the trailer body and gas tanks. I would have liked to put a disconnect Perko type switch on mine, but could not find any place to mount it.
Old 01-20-2015, 08:41 AM   #3
dznf0g's Avatar
Oswego , Illinois
Ditto idroba...but I would use a plastic electrical box....just to ensure the lowering of any short circuit chances.
-Rich-
Old 01-20-2015, 10:51 PM   #4
New Borockton , Alabama
Images: 21
Your shunt is not going to get hot. Especially if its the 500 amp that I recommend. Even the 100 won't over heat as long as your charge current doesn't exceed 70 Amps. 400 for the 500 amp shunt.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 01-21-2015, 06:00 AM   #5
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
The shunt won't get hot and since it is in the negative lead there is not a real reason to go to great length to box it as if it were to short to ground no harm would be done, just erroneous readings.
I originally had mine right at the battery terminal. Later moved it to outside the battery box when neatening up my wiring. I also changed from the 500 amp shunt to 100 amp shunt for more accurate readings.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 01-21-2015, 07:28 AM   #6
2013 20' Flying Cloud
Between Here and There and Nowhere , what have you got?
What's the best position for the shunt location so I'm reading Both batteries? Another poster placed his between the batteries, which looked to me to just read one battery.
openroad118 is offline   Reply With Quote
Old 01-21-2015, 07:39 AM   #7
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
You have to change the cabling of the factory setup so that the shunt is in the negative path between the load and the batteries in parallel.
Larry
lsbrodsky is offline   Reply With Quote
Fresh water shunt installed Excella CM Fresh Water Systems 5 01-19-2010 12:13 PM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
Anyone out there with ammeter/shunt experience? johnobuttons Lights - Interior & Exterior 2 08-16-2009 11:40 PM
TriMetric 2020/2021 shunt - 100 or 500 amp? ostream Electrical - Systems, Generators, Batteries & Solar 3 11-06-2008 02:37 PM
