Old 05-12-2016, 11:14 AM   #1
1988 32' Excella
Vestal , New York
Triad Utrad TU 750-6 Converter
I just unearthed my poorly functioning power converter and discovered it to be a Triad Utrad TU 750-6 Converter. An internet search seems to indicate that the company is no longer in existence. Some one had wired in a small battery charger with a switch to turn it and the converter on and off. It never kept the battery charged. Based on a previous thread, I bought a Progressive Dynamics PD 4655V 55 amp power converter which is sold as a replacement/upgrade for the following: Parallax/Magnatek model 6355, Parallax models 7355 and 7155, and WFCO model 8955. So, a couple of questions: Will this unit successfully replace the Triad unit, and if not, what will. I haven't monkey with the new unit, so it is returnable. Any help would be greatly appreciated.
Dan Barker
Dan Barker is offline   Reply With Quote
Old 05-12-2016, 12:46 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
You should be good to go. I suggest you also buy the Progressive Wizard Monitor. That will let you know just what is going on with the charger and manager the charging rate.
2004 Excursion 4x4
Heading to Winnipeg from Triad area NC damascus On The Road... 9 12-29-2015 05:50 AM
Converter Charger Triad-Ultrad gretaseyr56 Airstream Classifieds 0 07-22-2014 07:20 PM
Triad-utrad TU-430-2 charger Dan S All Argosy Trailers 2 04-17-2012 10:04 PM
750# or 1000#?? Sundance Hitches, Couplers & Balls 7 04-17-2007 04:42 PM
