Old 02-22-2010, 03:57 PM   #1
fotochop's Avatar
1969 23' Safari
New Orleans , Louisiana
Images: 18
Tracing 12v Circuits, Shorts...First Steps
* '69 Safari 23 foot with
* Intellipower 30 amp Converter, functional
* new Die Hard deep cycle battery
My rig recently started blowing fuses intermittently and, being in the middle of reading "Managing 12 Volts" by Mr. Barre (good book, thanks Randy) I figured its time to start tracing my 12 volt circuits to try and zero in on the problem....
I don't have a schematic but its possible the wiring is not original to the trailer (I don't see any aluminum wiring, for example, and its possible the 69's had it orginally but a p.o. replaced it/rewired it...
I want to try and map out my own schematic particular to this trailer. I'm taking baby steps here, folks
I'm plugged into shore power, a 20 amp circuit in my garage.
Here's a photo of the fuse panel. You can see where a p.o. added a kill switch to the battery. Rig had a Univolt when I bought it and I was told to kill the battery "when it started to boil" (are there crawfish in there??) I have since upgraded to the Intellipower converter.
I'm starting out by seeking the feed wire from the converter to the fuse panel. I disconnected the wire marked "13.43" (volts dc) from the panel and took a reading: 13.43 v DC
While this wire was disconnected I read other red wires (positive, right?) and they all read "12.89", which was the same reading at the battery, which was not disconnected at this point.
Is it safe to assume my 13.43 wire is the feed from the Intellipower? That's almost the exact output reading from at the converter.
I'm more than a little confused by the added switch and lamp-cord at the fuse panel. A parallel circuit is a bit more tricky to wrap my visual-learning-brain around than a simple, circular series circuit...
I really appreciate a few electro-wizards opinions here. You can click on the picture to enlarge it if necessary..
I will update this thread as I proceed....hopefully my sleuthing will eventually point out the short/problem...
fotochop is offline   Reply With Quote
Old 02-22-2010, 04:09 PM   #2
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
Rick,
Taking just one part of this (so plenty left over for more experienced ones than I):
Disconnect the 110vac to the Intellipower (kill AC power to the trailer is easiest way, unless you have a direct visual on a switch to turn off just the Intellipower). I'd rather kill power to just the Intellipower so I am sure I'm ONLY turning it off.
Then read the 13.43 circuit -- now it's zero, and you're sure it is the Intellipower because nothing else in the trailer is converting power and would be interrupted by the break in the AC power.
Good luck,
Chasing 75 Degrees,
Jim N5RTG
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Old 02-22-2010, 04:17 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
That's a kill swiitch for the battery? It doesn't look like it has near big enough guage wires coming out the top and bottom of the metal box. That panel looks like a jury-rigged mess. I'd strongly consider replacing the whole thing.
Chris
Old 02-22-2010, 04:26 PM   #4
Ottawa , ON
Chris
And to do that, he needs to have a schematic of his actual wiring. I think that's what he's doing...
"When you don't know where you're going, any road is the right one."
Old 02-22-2010, 05:27 PM   #5
richinny's Avatar
2011 34' Classic
which fuse is blowing?
Ricky
Old 02-22-2010, 05:38 PM   #6
fotochop's Avatar
1969 23' Safari
Images: 18
First it was the "13.43 volt" fuse which appears to come from Intellipower converter, then I blew the third fuse from the top after turning all the interior lights on.
(another in a series of dumb questions...): Since the Intellipower is a 30 amp unit and has two blade-type 30 amp fuses protecting against wrong battery polarity, shouldn't the Intellipower glass fuse in the fuse panel also be a 30 amp? The one that blew is a 20 amp (but formerly, probably was hooked to the Univolt). just wondering, but don't want any fires...
Old 02-22-2010, 09:09 PM   #7
richinny's Avatar
2011 34' Classic
i just have some general answers.
you have a voltage drop across the "intellipower" fuse in the block. see if you can clean those clips. this can cause excessive current draw.
add up the amperage of all the items you had on when the other fuse blew. it might have exceeded the limit of the fuse.
i'll leave the other questions to the experts.
Ricky
Old 02-22-2010, 10:01 PM   #8
Wise Elder
Jammer's Avatar
2010 30' Classic
The block you have the ??? on is a shunt for measuring current. The gray wires from it go to the top two fuses and should go from there to an ammeter.
The wire to the intellipower appears to be at least 10 gauge, maybe 8. If so, you can fuse it at 30 amps. You could actually fuse it for more than that but those fuse holders won't take a bigger fuse.
Old 02-23-2010, 12:31 AM   #9
Mexray's Avatar
1978 28' Ambassador
Morada , California
Rick...
I'll try to shed some light on your PO's 'rats' nest, so to speak...
1. dump that 'kill' switch - it's way under rated for heavy DC amperage use...the contacts get burned quickly - they just aren't designed for DC use...If you're going to use a 'kill' switch on a DC wire to the batteries, get a quality DC rated switch, and use 8 or 6 gauge wire to keep the electrical resistance to a minimum - the larger the better, in any event don't use a smaller gauge wire than the feed wire from the batteries themselves...
2. what appears to me as a metal plate where your '??' is shown would be acting as a tie plate for the + side of the DC source - all those wires should be = to the battery POS voltage...notice all those wires feed the 'supply' side of the fuse panel, plus the black wire with the yellow terminal that apparently feed 12 volts + to the light socket at the top...
3.It appears that the wires from your batteries are the red and white heavy wires that enter from the upper RH side of your picture - is that true? You can check with your meter by removing the fuses...If so the red wire passes thru the fuse from right to left, then thru the red wire on the LH side of the fuse, down to the metal plate (in 2 above) to power that tie plate with 12 volts-POS for the other circuits via the wires running back up to the fuses...
4. The white wire from the batteries goes thru the fuse from right to left and then continues to some grounding point (or the NEG side of the converter/charger.
5. it looks like the red wire marked with the '13.43' is indeed the POS wire from the converter/charger...
6. perhaps the white wire right below the '13.43' wire is the NEG wire from the converter/charger and goes thru the fuse, then down to the same grounding point as the white wire noted in #4 above.
7. my fuse panel uses 50 amp glass fuses for the battery POS and NEG feed wires - they are noticeably larger in diameter than the other fuses and use larger fuse clips as well - I would recommend using at lease 50 amp fuses for the battery feeds...
8. It's a bit unconventional to see 'feed' wires coming from both sides of the fuse panel - all 'feeds' (or supply) wires should be on one side and the 'load' wires on the other so things don't get confused (no pun intended) when tracing problems, etc....
9. Also, I'd recommend replacing those small diameter twin lead wires with some good automotive stranded wire - I like to use at lease 10 or 12 ga wires for the accessory feeds, and larger 8 or 6 ga for the battery feeds...
10. If those wires have been in place for many years, the copper strands at the ends (where connected) become oxidized, turning brown or black in color and cause resistance in the low voltage DC circuits - I'd remove all the wires, clean the strands, or replace where possible, or even cut back the wire to get some 'new' material and use some anti-corrosion goop on the wires before sticking them back into the fuse panel with the set screws...
Hope that helps...
Ray near Lodi
Ray & Pat; Morada, CA
Old 02-23-2010, 12:52 AM   #10
Maniacal Engineer
barts's Avatar
Menlo Park , California
how about a short sound?
One method of debugging intermittent shorts that I like a lot is to use a 20A DC circuit breaker with wire leads and alligator clips; the kind that automatically resets itself is handiest when working alone. You also want a noise maker of some sort (Radio Shack has 'em) that will work on 12 V, also connected to the alligator clips. If the noisemaker cares, make sure to mark the clips as to polarity... now, remove the blowing fuse and connect the circuit breaker clips across the fuse holder. Turn on the circuit and start wiggling wires, etc, looking for the short. When the short trips the breaker, the noisemaker will sound, and you have an idea where the problem is. The breaker will soon reset, and then you can pin it down some more.
I once traced an intermittent fault in the wiring on my truck this way; turned out the tailgate was pinching the camper shell rear light wires, so whenever I stepped on the brakes hard the tailgate would pinch the wires and eventually caused the short... the dealer tried and couldn't find it; I drove w/ this for a day and bingo.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 02-23-2010, 03:51 AM   #11
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Hi Rick;
Please allow me to UN-CONFUSE you first. First of all you must keep your circuitry straight. Separate AC and DC, as they are separate circuits if you disconnect the Intellipower. Your Intellipower converts AC [alternating] 115 Vac 60 Hz power to 13.5 VDC offering you converted 13.5 Volts DC [direct current power] and battery charging capability. Separate the two circuits first, by removing the Intellipower leads to the battery. Disconnect the batteries. Now you can check your 12 VDC trailer circuitry.
Using Ohm meter set to hi Ohm scale using jumper extension wire, hook up one meter lead to positive battery lead [not the battery] With all switches in off position and fuses out check the positive input lead to your fuse block. If you have continuity your lead is OK. Now switch the one lead from positive side of the fuse block to negative post on the fuse block. If continuity is present your negative lead is shorted to positive side. If no continuity between positive and negative, your input wires to fuse block are OK.
Now you need to check individual circuits in the trailer. Install appropriate fuses in the fuse block. Disconnect your meter lead from battery cable and hook it to positive side on the fuse block input. With all bulbs out of the lights and battery power still disconnected check for continuity to bulb sockets [do not forget to turn on the switches]. In this test you should have continuity only to one pin in each socket. Continuity on both sides of the socket indicates short in that circuit. Do not forget to check input into other circuits such as fans and appliances.
Next step is to remove the meter lead from positive side on the fuse block and place it on Negative side of fuse block. Repeat the tests in the sockets to make sure only one pin in the socket has continuity. Continuity on both pins indicates short to positive side. While doing this, tag all fuses so that you now in the future what they serve. If all checks OK [no shorts] replace all bulbs and reconnect appliances. Having the fused circuits tagged connect both battery leads. Install one fuse at the time and turn on any switches operating from that fuse one at the time. If the fuse blows you know which circuit is shorted by having them tagged. Repeat the process with the rest of fuses. Good luck "Boatdoc"
boatdoc is offline   Reply With Quote
Old 02-23-2010, 12:40 PM   #12
fotochop's Avatar
1969 23' Safari
Images: 18
More Baby Steps..
Originally Posted by boatdoc View Post
Hi Rick;
BOATDOC YOU ROCK
Excellent summation, I am grateful to you and other contributors..I have printed out and will execute
(electro-newbs like me should print this out too..)
I have i-d'ed Converter pos & neg leads (I think) by extending multimeter leads with wire/alligator clip arrangement shown below:
above photo shows me trying to i.d. converter ground lug wire back by the fuse panel, but I got a continuity beep at a bunch of the fuses and trailer body....... normal?
and am starting a circuit map:
next step (for me, anyway) is to bypass battery switch by running a new 8ga. wire from left side of Converter pos lead at fuse panel directly to battery.. I plan to change/upgrade the battery terminal connections to wire loop and attach with wing-nuts instead of mangled old connections unless somebody says don''t do it/bad idea..
You can see I'm space-challenged back there and disconnecting (not to mention removing) the battery is quite an...adventure I'd love to move battery & install a nice new fuse panel under the gaucho but don't have time at this juncture...that'll have to go on the do do list...
Old 02-23-2010, 12:58 PM   #13
fotochop's Avatar
1969 23' Safari
Images: 18
one more thing: I notice some people add a circuit breaker between the battery and fuse block.. Is this something I should do? 12 volts, ?? 30 amp? If so, I might simply put it where the battery switch is and up-gauge the wiring, yes?.... thanks
Old 02-24-2010, 04:16 AM   #14
boatdoc's Avatar
1973 Argosy 26
Hi Rick; Converter test is simpler than what you trying to do. Simply disconnect converter leads from battery and check for 13.5 -14.7 Volts output. Converter having numerous diodes is beyond your capability to test other than voltage output. Amperage output is depended on demand and it's capability. Your short which blows fuses has nothing to do with converter. Using Ohm meter you need to ring out your 12VAC wiring in the trailer. Be sure that no battery or converter power is connected to them, or you will fry the Ohm meter. You are only testing wire continuity and finding out which wire is connected to which circuit. Remember this; each circuit must have a positive lead and negative to work. For instance, If you remove bulb from it's socket the connection between positive and negative is broken and no current can flow from one wire to another. The filament inside the glass bulb enclosure is in gas environment and void of oxygen. Nothing burns without oxygen, right? The current flowing from positive side to negative when the switch is turned on flows through filament which is nothing more than resistor. The amperage flowing through that filament is converted into heat energy creating the light. Do you remember what happens when glass of the bulb cracks? The bulb's element burns out in presence of oxygen. Bulb element is made of tungsten, a very dense metal composition which will not melt unless oxygen is present or amperage flowing through it is higher than the filament can pass without burning up. Wire however will melt instantly in presence of oxygen given enough amperage flowing through it. This is why the fuses are incorporated into circuits. Fuse is normally capable to pass only a portion of amperage, of that what the wire can carry. When the load demand in the circuit exceeds fuse amp rating, the fuse burns out thus protecting wiring and final components from damage. Motors such as fan may have carbon brushes which pass the current into field windings when the switch is turned on. Others may be inductive type but they all work on the principal of current flowing from one side to the other. At this point I better leave the theory alone of how the electric motors work without burning up i oxygen atmosphere because it is too involved, and you most likely will not be repairing them. So, ring out all wires with final components disconnected. There should be no continuity between the pos. and neg. wire with final componnents disconnected. You should have continuity between both ends of each individual wire, if not the wire is broken an needs replacing. If wires checked out Ok and the fuse blows when you connect the wires to a light or a motor, that component is shorted internally. Very occasionally switches made of metal case and mounted in chassis grounded material may short out to ground and may have to be checked. Neither side of the switch posts should have continuity to ground. As I have said it does not happen very often but pending the construction of the switch it can happen. Good luck Rick. "Boatdoc"
12v
Correct size fuse for 12V circuits FLYNCLD Batteries, Univolts, Converters & Inverters 7 04-23-2009 05:39 PM
Tracing a short LI Pets Lights - Interior & Exterior 10 04-30-2007 10:59 AM
Finding electrical shorts Cap-N-Red Lights - Interior & Exterior 2 03-19-2007 06:50 AM
various shorts solved, few minor questions richard77 Electrical - Systems, Generators, Batteries & Solar 4 10-04-2006 07:59 PM
12V circuits dmadam Electrical - Systems, Generators, Batteries & Solar 7 04-07-2004 03:03 PM
