Old 07-11-2010, 07:02 PM   #1
ESCAPE POD's Avatar
2007 19' Safari SE
Seal Beach , California
Tow vehicle not charging battery
My 2010 Ford F-150 is barely charging the battery, even after 200mi+ of driving . Generator and shore power do fine as charging sources, and the battery holds a charge OK, so I'm pretty sure it's the truck. My '03 Dodge Dakota did a fine job of charging, BTW. If I take the F-150 in to check out the charging system, what should the service techs focus on? Thanks for your help!
-Jerry
"I have found through trial and error that I work best under duress. In fact, I work only under duress." -Ed Abbey
Jerry & Susan
2007 19' Bambi SE; 2010 Ford F-150 5.4L SuperCrew 4x4 w/ FlipPac camper shell
ESCAPE POD is offline   Reply With Quote
Old 07-11-2010, 08:38 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Some manufacturers do not install a fuse in the charge line circuit at the factory. You might want to look at the fuses in your truck.
Richard
Old 07-11-2010, 08:42 PM   #3
Iwannagocamping
Dakota's Dad's Avatar
Rineyville , Kentucky
Yeah, even though delivered with a "towing package" We had to go in and insert a couple of fuses, and 1 for sure was the charging circuit.
See our blog here on how two RV/AS rookies tackle a 1979 Sovereign resto!!
Just the photos.. (sometimes you don't need the blog, just a picture worth a thousand words..)
1979 Sovereign International
2004 Ford Expedition Eddie Bauer
2 Golden Retrievers
Air #36788
TAC#3179
WBCCI #1265
Dakota's Dad is offline   Reply With Quote
Old 07-11-2010, 09:46 PM   #4
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
-Jerry
Hi Jerry,
I just bought a 2010 F-150, too, and had this same exact problem with the charging circuit. When you bought your truck you should have gotten a clear plastic bag with a wiring harness for a brake controller. In that same bag you'll also find a fuse and relay. If you haven't done so already, plug these in. I believe the fuse positions are 9 and 21 (check your owner's manual).
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-11-2010, 10:46 PM   #5
2008 16' International CCD
kitimat , british columbia
Maybe someone can clarify this for me, but does your unit as well have to he in the "in use" mode, as compared to the "storage" mode in order for the battery to charge?
Snowey BC is offline   Reply With Quote
Old 07-11-2010, 10:53 PM   #6
ESCAPE POD's Avatar
2007 19' Safari SE
When towing, the battery is always "in use" mode, if only to keep the fridge running. But to answer your question: yes, the battery can't charge if it is "storage" mode.
-Jerry
Jerry & Susan
Old 07-11-2010, 10:57 PM   #7
ESCAPE POD's Avatar
2007 19' Safari SE
Thanks, everyone! I found the relay and fuse in the glove box. Can I just plug them in, or do I have to disconnect the battery before doing so? If disconnected, the battery has to undergo a "relearning" process that sounds like a PITA!
-Jerry
Jerry & Susan
Charging Airstream batteries from tow vehicle Jammer Batteries, Univolts, Converters & Inverters 18 10-09-2011 09:28 AM
Charging Battery From Tow Vehicle boutdoors Boondocking 25 09-06-2010 05:35 PM
Tow vehicle charging batteries safari 28 Batteries, Univolts, Converters & Inverters 25 11-15-2009 10:28 PM
Battery charging from tow vehicle ? rwnash Batteries, Univolts, Converters & Inverters 3 07-29-2008 08:17 AM
Charging the batteries using tow vehicle bci 2006 - 2010 Classic (all lengths) 22 06-09-2008 09:57 PM
