Old 12-31-2008, 11:33 AM   #1
safari25-05's Avatar
summerfield , Florida
tow vehicle charge line to trailer battery..
I was wondering because the trailer battery is so far from the engine alternator and tow vehicle battery, would a battery separator or a battery isolator be a good idea? Because.. once the vehicle battery is charged and the other battery is so far away, how does it ( alternator) know that the battery in the trailer needs charging beyond the needs of the primary vehicle battery? Because.. I am running the refrigerator in gas mode which still uses some 12 volt electric while traveling. Thanks for any feed back.
safari25-05 is offline   Reply With Quote
Old 12-31-2008, 11:46 AM   #2
Gene's Avatar
2008 25' Safari FB SE
Crawford , Colorado
Safari, happy birthday. Welcome to old age.
My not too great understanding is that recent model trucks with a tow package should have a battery isolator, heavy duty alternator and larger battery. I believe (and surely will be corrected if I'm wrong) is the isolator charges the truck battery first and when it is fully charged, charges the trailer batteries. Reddy Kilowatt's little brother may be inside the isolator making that decision, but more likely it's transistors and capacitors.
Since you have an older truck, check with the service dept at a dealer and they should be able to tell you exactly what you have from all those strange numbers in the VIN. If you bought the vehicle used, someone may have added after market equipment and either the dealer or a reputable RV shop could check for these items. Though the tow vehicle doesn't really provide all that much to charge the trailer batteries, it's plenty for the igniter and electronic stuff in the refrigerator and other accessories (such as the propane detector) that are used while traveling.
Gene
Old 12-31-2008, 12:38 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I tow with a 99 Dodge Dakota that did not come equipped with a tow package. I had to add the isolator for the trailer battery along with the brake wiring, etc.
Old 12-31-2008, 02:25 PM   #4
SteveH's Avatar
2010 31' Classic
Common Sense , Texas
I know I will get disputed on this, but here goes....you really don't need an isolator. All the isolator does is not allow the trailer to discharge the truck battery, or vice versa. When the truck and trailer batteries are tied together in operation, the alternator sees one load, and the battery with the lower voltage, gets the most charge current until it equals the other battery, and then they get the same current until the alternator regulator cuts back. If you do not have an isolator, it is a good idea to disconnect the trailer electrical from the truck when you park for the night.
"The further a society drifts from the truth, the more it will hate those that speak it." George Orwell
In the past: '73 20' Argosy, '74 24' Argosy, '75 23' Avion, '63 24' Airstream, '78 24' Argosy, '75 23' Airstream, '01 25' Airstream, '04 28' Airstream
Old 12-31-2008, 02:36 PM   #5
1975 29' Ambassador
Reno , Nevada
What happens is that it just takes longer to bring the RV battery up to full charge.
The vehicle charging system senses the chassis battery and often has a separate lead for this. Once that battery is up to a proper float voltage, the system keeps it there.
So the situation is that the charging source quickly gets the chassis battery back to a float voltage yet the RV battery is still discharged because current to it has a lot of resistance to get through. The RV battery will then continue to charge because it is below the charging system's float voltage. The charge current will be limited by the resistance in the feed line plus the fact that the source voltage is not very high. That is most of the reason why it can take quite a while on the road to get the RV battery charged up.
When the battery gets up to a full charge, it will no longer accept current at the float voltage level and the very low currents nearing that point mean very low loss in the charging line. So it gets there, it just takes a while.
Note that the ground return on the RV battery is often a good source of resistance itself and a common source of problems.
A properly wired vehicle charging system that supports both RV and chassis batteries will have precautions against draining the chassis battery with RV loads. This can be a relay that will close only after the engine is running and the charging system functioning or it might be a diode isolator. The diodes have fallen out of favor because they impose a voltage drop that slows charging and prevents full charging.
Old 12-31-2008, 03:00 PM   #6
Aerowood's Avatar
Arvada , Colorado
I put the isolator in to protect the tow vehicle charging system in the event that something goes amiss with the trailer, I also installed a circuit breaker downstream of the isolator for extra protection. Call me paranoid
Old 12-31-2008, 04:00 PM   #7
87MH's Avatar
1978 31' Sovereign
Texas Airstream Harbor , Zavalla, Deep East Piney Woods, Texas
Images: 281
What is the gauge of the charge line?
Originally Posted by safari25-05 View Post
I was wondering because the trailer battery is so far from the engine alternator and tow vehicle battery, would a battery separator or a battery isolator be a good idea? ....
Interesting that you should bring this up - the charge rate/voltage available at the trailer battery is HUGELY dependant on the size of the wire between the Tow Vehicle alternator and the trailer battery.
Example - for a 20 amp charge rate a typical charge line (both positive AND negative connections) would require a #4 wire - decrease that size to #6 if you would be happy with a 15 amp rate.
As mentioned earlier, there would be a sever amperage blockage at the coupler unless an additional (properly sized) negative jumper line were installed between the TV and the trailer.
Note that most typical 7 pin trailer/TV jumper lines are woefully inadequate to carry much of a useful amperage load.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Battery charging from tow vehicle ? rwnash Batteries, Univolts, Converters & Inverters 3 07-29-2008 08:17 AM
what to charge to tow a trailer zoeb nj Tow Vehicles 9 04-18-2008 08:17 AM
Battery Charge from Tow Vehicle Wardinbb Batteries, Univolts, Converters & Inverters 13 12-08-2004 05:35 PM
Silverado trailer charge line Safari Tim Tow Vehicles 11 06-24-2004 07:57 PM
Hooking Up Trailer Battery to Tow Vehicle flyfshr Batteries, Univolts, Converters & Inverters 11 02-27-2004 10:50 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
