Old 05-21-2018, 08:47 AM   #1
CaliBamb's Avatar
2003 19' Bambi
Breckenridge , Colorado
Tow vehicle batt vs Trailer Lithium batt while driving
I know this topic has been discussed before but looking for an answer if I should be pulling the 12 V connection in my airstream or is everything going to be just fine as is? thoughts.
I also saw there was some in line converter that would protect each thanks
CaliBamb is offline   Reply With Quote
Old 05-21-2018, 09:01 AM   #2
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
Lithium while driving
Great question. We just this morning contemplating upgrading our 2) 4 yr old 12v Interstates for two of the the highly regarded Battleborn Lithium’s being a drop in replacement but wondering if truly needing to replace everything else right now.
Hear they have built in battery management electronics to work smarter with brute force single stage charging/converters but will upgrade ours to the PD ...55 anyway for lithium jumper and higher current charging.
Vantair is offline   Reply With Quote
Old 05-22-2018, 06:29 PM   #3
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
The BMS connected to the Li-ion battery should take care of any charging issues. There is a setting in the BMS that switches off the charge current when the programmable final battery voltage is reached.
I know that my setup works that way.
sgschwend is offline   Reply With Quote
Old 05-27-2018, 07:47 PM   #4
2015 30' Classic
Pleasanton , California
The concern is that the TT can pull current from of the lithium batteries because their voltage is higher than the TT's voltage.
See this thread for a more detailed discussion.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
camera for viewing behind trailer while driving dearles 2005 and newer - Bambi all models 72 04-14-2018 07:35 AM
Self driving Tow Vehicle? sallye Towing, Tow Vehicles & Hitches 25 01-12-2016 07:46 PM
Lithium Batt Solar Install 2015 Classic ghaynes755 Generators & Solar Power 54 12-14-2015 12:42 PM
Preheating trailer while driving danlehosky On The Road... 8 12-31-2011 09:19 PM
Heat while driving? Krazykraut Airstream Motorhome Forums 4 12-08-2002 05:31 AM
