Old 07-01-2012, 11:53 AM   #1
4hartungs's Avatar
1996 30' Excella
Cloquet , Minnesota
to plug in or to not plug in...that is the questions
We are "weekend warriors at this point and wondering if it is best to plug-in to power when we are home and not planning another adventure for a couple of weeks or a month? Or would it be better to let everything defrost and then restart while we are not using it? Any advice is greatly appreciated.
2000 Miles to Graceland - "Gracie"
1996 Airstream 30' Excella
4hartungs is offline   Reply With Quote
Old 07-01-2012, 12:03 PM   #2
2012 25' Flying Cloud
Eureka , California
We don't plug in until the night before leaving. Even that is probably not necessary. The fridge gets cold enough pretty fast. (We drive with it on). Haven't had any spoiled food yet.
redwoodguy is offline   Reply With Quote
Old 07-01-2012, 12:16 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Our trailer is plugged in 24/7 when we are home. I remove the battery and use it for other things. The refer is turned off. All other devices have power if needed.
Old 07-01-2012, 12:19 PM   #4
techiej's Avatar
2011 34' Classic
Vancouver , Washington
We keep the AS plugged in but if it's going to be a week or more between uses we turn off the fridge.
techiej is offline   Reply With Quote
Old 07-01-2012, 12:32 PM   #5
2005 19' Safari
GLENDALE , AZ
If you have the OEM converter, leaving your Airstream connected to shore power 24/7 may eventually overcharge and ruin your batteries. If you decide to do this, you may wish to consider upgrading to a multi-stage converter, which will prevent overcharging; or you can install a marine battery isolator switch, which will allow you to turn your batteries OFF during long storage periods. Use SEARCH to find more info on these topics.
Old 07-01-2012, 01:06 PM   #6
1974 Argosy 20
Kooskia , Idaho
If you leave the refrigerator on, it will average 200 to 250 watts of draw, or about twice to 3 times what your modern home refrigerator will take. At 250 watts, you will be paying for about 6 kwh a day, or at the average national energy rate of 12 cents a kwh, close to 75 cents a day. So, a two week cost of it being on would be about $10.50. I would rather spend that money on something else.
Also, as mentioned in other posts, if you do not have a modern 3 stage converter/charger the batteries are subject to overcharge when plugged in but not in use.
Old 07-01-2012, 01:29 PM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
When it was being used we would plug in 24 hours prior to leaving. In reality it was turn the breaker on 24 hours prior to leaving. We would plug it up when we came in. At the time it was also being used as a guest cottage, the breaker is in the panel at the house, the Airstream is parked 75 feet away.
Aaron
WBCCI #XXXX AIR #2495
Old 05-22-2013, 02:36 PM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
X2
Original converter?....I would not leave it plugged in without checking the batteries every couple daze. Not very convenient.
Our Classic was plugged in 24/7 on the dealer lot and the batt's lasted a
month when we got it home.
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 05-22-2013, 07:07 PM   #9
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We leave our Bambi plugged in between trips and we leave the frig on to use for extra storage, etc (other than those times when we are not camping for a month or longer). We also have the AC set to run if it gets too hot inside. It's sheltered from the sun, but in our summers it still gets very warm inside without AC.
TB & Greg and Abbey Schnauzer
#3954
Old 05-23-2013, 01:13 AM   #10
2005 19' Safari
GLENDALE , AZ
Not sure if I mentioned before, but you can leave your Airstream plugged into shore power 24/7 and run all 120-volt AC and 12-volt DC appliances with your batteries disconnected, using a marine battery isolator switch set to OFF position. This allows converter power to supply 12-volts DC while your batteries are completely disconnected from your Airstream, thus protecting them from overcharging.
Old 05-23-2013, 06:23 AM   #11
2013 20' Flying Cloud
Cream Ridge , New Jersey
We leave ours unplugged with the batteries disconnected and a small maintenance charger hooked up to the batteries. We only plug it in when we are prepping for a trip or doing some (make believe) camping on one of those rainy weekends.
Joe Palmieri is offline   Reply With Quote
Old 06-26-2013, 12:49 PM   #12
LFC
Memphis , Tennessee
I just got off the phone with Airstream Technical support and was told that the convertor that came in my 2000 Safari would not over charge or hurt my Omni battery.
He informed me that the only time they have saw the convertor they use damage a battery was with a dual battery system that had one bad battery causing the good battery to over charge.
LFC is offline   Reply With Quote
Old 06-26-2013, 01:11 PM   #13
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
They tell you that because they're using the same sort of converter today to save $25 per trailer, so toeing the party line means they need to say those converters are just fine. If you just travel on weekends with the occasional longer trip AND don't leave the trailer plugged in when you're not using it, you'd likely never know that the one-stage converters overcharge, but that's just because they don't have enough time to ruin the battery before the battery is old enough that you'll just chalk a failure up to the age of the battery.
— David
Old 06-26-2013, 01:19 PM   #14
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
We leave ours plugged in 24/7 and have yet to ruin our Optima batteries. We do defrost the frig and clean it between trips with a couple of "Hold Open" devices holding the doors open slightly to keep the frig aired out.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
