Old 07-05-2013, 09:00 AM   #29
LFC
Memphis , Tennessee
Originally Posted by ROBERT CROSS View Post
Omni=Lithium?
If it's a P-Lax it's junk, our 7455 fried the Factory batteries while on the dealer lot, and the second pair 18mos later.
Two sets of bad batteries, I don't think so.
IOTA DLS 55a IQ4 and two Lifelines, 5 Seasons and counting.
At your recommendation I bought the IOTA DLS 55a IQ4
LFC is offline   Reply With Quote
Old 07-16-2013, 12:54 PM   #30
janeinthemtns
1985 31' Excella
near Chama , New Mexico
Can someone tell me where the inverter and converter is located in an 85 Excella? I would like to see what I've got. I have a solar panel. I can see it from the second story of the house. The refrigerator worked until I unplugged the pickup. Now only the lights and fan work. One of batteries is disconnected. Everything is working in the trailer. It was thoroughly checked out at Holiday in Albuquerque before I brought it home. I'm on a learning curve here. It's a steep one. Thanks for any info.
janeinthemtns is offline   Reply With Quote
Old 07-16-2013, 04:00 PM   #31
LFC
Memphis , Tennessee
Should be in the front possibly under the couch.
Old 08-11-2013, 02:26 PM   #32
2013 16' Sport
Boulder , Colorado
Can anyone confirm that I have a 3-stage converter/charger factory installed in my 2013 Bambi Sport? It is a WFCO "Power Center". The part # is WF-8955ANPB and not listed on the website, although the description of a similar part (WF-8945ANP) indicates 3-stage charging. The AS user manual simply says "Although the converter is an excellent battery charger, the converter does not require a battery to be connected to it for proper operation". I am assuming that the converter I have is 3-stage, and I don't need to worry about leaving the AS plugged in at home to maintain the battery. Am I right?
Seecue is offline   Reply With Quote
Old 08-11-2013, 04:30 PM   #33
aftermath's Avatar
Spokane , Washington
You have a converter that "converts" your 110 household power to 12 volts to run all the lights and appliances in your trailer, except for the AC of course. It also "converts" the 110 into 12 volts to charge your house batteries. It is the charging feature that is at question in this thread. A modern 3 stage charger will charge AND protect your batteries from over charging. Your converter will not keep your batteries charged when you are not hooked up to power.
I purchased my 2006 in 2009 and the PO had left it plugged in almost continually from the time he brought it home. The batteries were toast and I didn't find out until I went out with it for our shake down trip. I learned all about sulphated batteries and the importance of a good converter. I now have an IOTA and am pleased with it.
aftermath is offline   Reply With Quote
Old 08-11-2013, 04:33 PM   #34
aftermath's Avatar
Sorry
Misread your post and didn't answer your question. When they said that you didn't need a battery connected simply means that your converter will continue to convert 110 to 12 volts even without a battery.
When they said it is "an excellent" charger I wouldn't assume that it is a three state charger without confirming that. Yes, they are great chargers but not ones I would leave my charged battery connected to. I hope that makes sense. I suppose it is always wise to check out claims made by any manufacturer, Airstream included.
Old 08-11-2013, 05:15 PM   #35
1974 Argosy 20
Kooskia , Idaho
I don't know for sure, but my 2014 FC 20' did not have a 3 stage charger system and it was one of the firs things I changed. But mine was a Paralax 55 amp converter charger. I changed it out to a 45 amp Progressive Dynamics with built in charge wizard which is their 3 stage unit.
Old 08-11-2013, 09:19 PM   #36
2013 16' Sport
Boulder , Colorado
Did a bit more internet digging and have confirmed that the stock "power center" in our 2013 16' Bambi Sport includes 3-stage charging: bulk at 14.4, absorption at 13.6 and float at 13.2. The product is from "World Friendship Company" (WFCO), a Chinese company whose name is a somewhat bad attempt at good marketing :-). Will assume this is a good product, until proven otherwise, and use it to maintain the battery between trips. But they recommend watching the battery fluid when plugged in to shore power for more than 30 days. So they acknowledge the possibility of boiling the battery, even with a 3rd stage trickle charge, if plugged in 24/7 over an extended period. When in extended storage, we will disconnect entirely (via an isolator switch if we can get that installed, so parasitic loads won't draw down the battery) and charge up once a month or so for maintenance. Please chime in if I am missing anything.
Old 08-12-2013, 04:24 AM   #37
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Colorado Winters....might be better to remove batteries during the off Season.
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
Old 08-12-2013, 09:29 AM   #38
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
When I bought my Argosy, it came equipped with a WFCO converter that had been installed by the PO several years before I bought the trailer. It took decent care of the battery for the first year I had the trailer. When the converter was about 4 years old it started to misbehave, I could see the lights getting brighter then dimmer every minute or so, and it was annoying. So, if it behaves like the one I had, you'll know if it goes bad!
As I said, it was on the order of 4 years old before it had a problem, and seemed to do a decent job up until then. I chose a different brand to replace it,*but it looks like that's something you can put off for quite a while. It doesn't hurt to put a voltmeter on it from time to time, to make sure that it's behaving as designed.
— David
Old 08-14-2013, 08:17 PM   #39
janeinthemtns
1985 31' Excella
Would you pull the batteries out even if you had the trailer plugged in? I'm down here in way north central New Mexico mountains.
Old 04-23-2014, 03:44 PM   #40
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Get a portable battery charger to keep the batteries up and everything else off. My father uses pro mariner for the many building generators' batteries around our area that he services. They found it to be a reliable option (after regularly replacing others)ProMariner
The Prosport line is what I have, the 6amp with one set of leads. I hook one lead to the negative of one battery and the positive to the other battery as they are parallel wired. Technically you can get the two lead model, the Prosport 12 and hook to both batteries for a supposed more accurate feedback to the charger. These are designed to be around water. Just remember to leave the interior battery switch on USE to charge the battery.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
