Old 06-26-2013, 01:50 PM   #15
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by LFC View Post
I just got off the phone with Airstream Technical support and was told that the convertor that came in my 2000 Safari would not over charge or hurt my Omni battery.
He informed me that the only time they have saw the convertor they use damage a battery was with a dual battery system that had one bad battery causing the good battery to over charge.
Omni=Lithium?
If it's a P-Lax it's junk, our 7455 fried the Factory batteries while on the dealer lot, and the second pair 18mos later.
Two sets of bad batteries, I don't think so.
IOTA DLS 55a IQ4 and two Lifelines, 5 Seasons and counting.
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
Old 06-26-2013, 02:42 PM   #16
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
We leave our's plugged in at home 24/7. Refer is on and has ice stored in the freezer to balance the run times.
As suggested above, I do use the stock battery disconnect switch to disconnect the batteries from the converter so as not to overcharge them.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 06-26-2013, 02:46 PM   #17
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
My 2000 Safari has it's original converter, but it is not the old Univolt. (Randy at Best told me what I have, but I can not remember) I do not know what year they stopped using the Univolt, but no longer.
I use a single wet cell deep cycle battery (cheap). I have had it connected continuously to 120v shore power, except for travel time and a few days of camping without hookups, for more than a year. I have not had any problems with the electrolyte evaporating excessively. I checked it last week and the battery did not need any water, though I did add water once last winter. I have checked the voltage output of the converter when the battery is fully charged, and find that it drops to an appropriate low charge level, 12.5v by my meter.
Alan
Old 06-26-2013, 03:24 PM   #18
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I found that leaving the power connected will accelerate the evaporation of the battery fluid. As long as you monitor that fluid level and keep it above the plates, you should be okay. I learned the hard way and did not and prematurely shortened the life of the first set of batteries.
Typically if the trailer is going to sit a week in the drive, I disconnect the power and do not plug it back into power until 48 hours prior to departure. At that point I'll turn on the fridge and get it cooled down.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-26-2013, 04:06 PM   #19
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
One of the reasons I ditched the stock charger/converter from my brand new trailer was to avail myself of the advantages of a more modern set-up (Iota DLS-55) that doesn't just recharge, but moves to "float" the battery. So, my trailer is always plugged into a 30 amp outlet.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 06-26-2013, 04:34 PM   #20
2007 23' Safari SE
Laramie , Wyoming
The cheap converter / charger in our 2007 International CCD did not work properly from day one. I installed a Zantrex 30 amp inverter / charger with full size battery cables in the front road side storage under the dinette seat. This is a proper multi-stage float charger and allows full 30 amp 120 volt AC power off the batteries. I can run all the AC stuff, but the big loads - air conditioner, microwave, coffee maker won't go for long on just the two deep cycle batteries. We pretty much always have a Yamaha 30 amp 120 volt generator with us as we're usually boondocking. Agree the stock converter / chargers seem to be quite minimal and cheap.
johnmh is offline   Reply With Quote
Old 06-26-2013, 05:41 PM   #21
2004 30' Classic
Hillsborough , New Jersey
AS plugged in while in storage
Unless you travel frequently, and want the trailer "ready to go" why waste the energy keeping it plugged in 24/7? I put the trailer plugged into a timer which turns on for about a two hour period in order to keep the battery charged. Wolf146
wolf146 is offline   Reply With Quote
Old 06-26-2013, 06:56 PM   #22
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I'm about to buy my first AS....
Interested in answer to this question - perhaps to run ventilation fan in summer to expel trapped heat?
PharmGeek is offline   Reply With Quote
Old 06-26-2013, 08:09 PM   #23
interstateflyer's Avatar
2017 25' International
Los Osos , California
I left my 2005 AS Interstate plugged in 24/7. Just sold it with the original LifeLine 12 volt. Also had a 125w roof solar panel.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 06-26-2013, 10:29 PM   #24
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Interstates have an inverter/charger, not the Parallax single-stage converter that trailers get.
— David
Old 06-26-2013, 11:33 PM   #25
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Plugged in 24/7.
Hi, my batteries are plugged in 24/7 to a Battery Tender Plus. My shore line cord is only plugged in a few days before a trip. And my refrigerator is only used on trips and emptied when we get home.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-27-2013, 04:13 AM   #26
LFC
Memphis , Tennessee
Almost two years ago I bought the biggest Optima deep cycle they made I first had it in a 1999 19' Bambi and now it's in a 2000 25' Safari....both had original convertors and were pretty much kept plugged in with no problems so far.
LFC is offline   Reply With Quote
Old 06-27-2013, 10:29 PM   #27
dirigible25's Avatar
1997 25' Safari
Yakima , Washington
I permanently mounted a plug in on my battery to quickly connect and disconnect a "Battery Tender". This will charge the battery to a certain level and then go to a trickle charge to maintain the battery at a peak charge without overcharging. I don't plug in the trailer itself to 120v. With the set up the way I have it, the fantastic fans can run (and close when it rains), and can use the 12V lights if need be. I do plug into 120V the night before we head out in order to cool the fridge. Never had a problem with this setup.
Dennis
1997 25' Safari
2012 Chevy Silverado HD 2500
Duramax/Allison
dirigible25 is offline   Reply With Quote
Old 06-28-2013, 05:08 AM   #28
Skater's Avatar
1995 30' Excella
Bowie , Maryland
It doesn't use that much, and it's nice to not have to unload things like mayonnaise, chocolate for s'mores, etc. Plus the power in our area seems to go out too often, and it's nice to have a backup fridge ready ro go. But we also go camping at least once a month from spring to fall...so it depends on your definition of frequently, too.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
