Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 05-23-2015, 03:27 PM   #1
1979 Argosy Minuet 7.3 Metre
Hill country , Texas
Time to upgrade the 12 volt fuse panel..suggestions?
Hi All,
My Lights in my minuet were flickering as we walked on the floor. I traced it to a loose rivet and bracket that holds the rivet on the positive side of the 50 AMP breaker on the fuse panel.
My fuse panel has the original glass fuses (It's the original Univolt as well).
The fuses are set up as following (from bottom up):
Batt charge pos :50 A
Main charge 30A
cir 1- 20 A
cir2- 20 A
cir3- 20 A
cir4- 20 A
I called around for a replacement, including vintage trailer, and they don't have fuse panels that took this many amps. The parellex, and Blue sea don't seem to be able to handle the 50 amp plus the other amps.
I asked a guy at a local boat store and he said since the 50 amp was the only one that was bad, I could install a Mini Max 50 AMP fuse and that would fix it.
This didn't work, the lights now don't work at all...Possibly because they're not on the same "strip" as the rest of the fuses?
Anyhoo- Guess I'm in for a new fuse box. Can anyone reccommend the proper panel/ box? Also, I'm running lamps until I get this fixed. That should be ok, because the plugs are tied to breakers, correct?
Many thanks for the info!!
ArgosyGypsy is offline   Reply With Quote
12 volt
Do I have to install a 12 volt fuse panel? knishiya Electrical - Systems, Generators, Batteries & Solar 15 02-09-2018 08:30 AM
12 Volt Fuse Panel Location Assistance Needed 2trackrr Electrical - Systems, Generators, Batteries & Solar 23 09-03-2013 03:33 PM
looking for a 12 Volt Fuse Panel Aage Batteries, Univolts, Converters & Inverters 7 04-08-2010 03:37 PM
Can't find the 12 volt fuse panel in my 1976 31 foot Sovereign clboyd Batteries, Univolts, Converters & Inverters 20 01-30-2009 06:02 PM
What size fuse for 12-volt panel? paddy79 Electrical - Systems, Generators, Batteries & Solar 4 05-23-2004 08:39 AM
