Old 04-29-2014, 03:38 PM   #1
kmaggard's Avatar
1994 21' Sovereign
Paradise Valley , Arizona
Time to check the Battery water
In my Sovereign with front battery boxes opening to the A frame it has always been a chore to get the batteries out. I had an idea today that I thought I would share. I made simple Blue straps that I looped on the back of the battery at the handle, ran them under the battery and gave my self a nice loop to lift them and slide them out.
We shall see if straps still hold in a couple of months, may have to switch to something corrosion will not get to. I do like the Airstream blue though.
I attached pics, I hope they can be seen.
ID:	210879   Click image for larger version
WBCCI# 2520
AIR# 77458
Ken and Ben the Saint
Paradise Valley, Arizona
kmaggard is offline   Reply With Quote
Old 04-29-2014, 04:04 PM   #2
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
Just checked the water in my batteries today also. Good idea with the straps. You should get no corrosion in the boxes unless one of the battery boils or leaks acid. With a regular maintenance schedule you will be good to go. One thing I did use to insure no sparks is to use a piece of sheet plastic on the top of the battery as I lift and slide the battery out. 27s' just fit!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Plumbing check- Water Pump blew water YoMoHo Fresh Water Systems 5 06-21-2013 12:35 PM
1st time check in ScottGriffin Member Introductions 9 06-28-2011 10:36 PM
Don't forget: Check your battery water level.... Safari Tim Batteries, Univolts, Converters & Inverters 2 11-14-2004 12:30 PM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
