08-21-2008, 09:31 PM
1977 Argosy 24
Austin
The 'Infamous' Univolt
Does anyone have a Picture of one of those bad boys??
Havent got to mine yet...i can see it down there......appears to be green in color...with white ends??
Thanks Big Mike
08-22-2008, 04:28 AM
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County
, New Hampshire
Thanks Big Mike
Gray or Green, that's probly a Univolt
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
08-22-2008, 04:42 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Thanks Big Mike
I have a picture but have to resize it first (both the univolt and the picture ) mine is blue and buried behind the bath tub.
Aaron
WBCCI #XXXX AIR #2495
08-22-2008, 05:10 PM
1999 27' Safari
Kent
, Ohio
I dont have a picture but I was told the Light Blue ones are the most reliable. My tan one failed I had a light blue one from an old trailer she is a good one
08-22-2008, 06:27 PM
Ham KI4HJX
1982 27' Excella
1970 23' Safari
Franklin
, 28734
Mine on my 82 Excella would burn battries up in short order. Even killed a gell battery that was said to be bullet proof. If you have a Univolt it's time to look for a new converter.
08-22-2008, 09:06 PM
1978 31' Excella 500
Venice
The scrap value of the copper will nearly buy a new type.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
08-22-2008, 10:39 PM
2004 31' Classic
lubbock
Whats a univolt?
And how do I know if I have one?
I know what a Uni-Brow is... but that has been corrected...
If I have a 1982 Excella would I have one...?
Does it hurt to have it extracted?
Do I replace it with a prothesis? Can you get one in flesh tones? Or maybe a leopard print?
08-23-2008, 02:47 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Jump...do you hear a humming noise, when the power is plugged in? IIRC yours should be under/behind the front gaucho.
Technology marches on, the new Progressive Intelipower are the only way to go, IMHO.
Aaron
08-23-2008, 04:10 AM
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
Thanks Big Mike
The only one I did not replace in my rigs was the 73 Overlander. It made very little noise and the output was right on. Never had an issue with the battery. Check your output with a multi meter.
http://www.vintagetrailersupply.com/?Click=155 is also a good source for replacements.
www.balrgn.com
08-23-2008, 08:20 AM
2004 31' Classic
lubbock
A humming noise???
[quote=wahoonc;607040]Jump...do you hear a humming noise, when the power is plugged in? IIRC yours should be under/behind the front gaucho.
Well....that brings up a whole lot of issues...sometimes the voices seem to be humming...but only when my mother-in-law or my sales manager is talking....and talking...and talking...I'm trying not to do what the voices tell me to do but it's becoming more and more difficult...
or did you mean only in the trailer? no, there's no humming in there...but we sing quite a bit when we are campin out....
08-31-2008, 12:21 PM
1980 28' Excella II
Schuyler
, Virginia
hey Aaron, my 28' 1980 Excella only have 30 amp AC at main breaker, when i replace univolt with Intellipower is it matter to use 45 amp or 60 amp unit from intelipower,
Aaron
08-31-2008, 12:45 PM
1993 34' Excella
Estancia
, New Mexico
[QUOTE=jump;607109]
Mine doesn't hum it chants ohm.
08-31-2008, 02:58 PM
1977 27' Overlander
Trotwood
, Ohio
Anyone know whats inside a Univolt or do I have to open that bad boy up?
I am getting really bad RFI in the am radio. I know "NO BODY LISTENS TO AM ANYMORE" In fact it is drowding out any signal on AM.
If its a standard inverter with cans and vibrator and Resistors I can handle that.
Roger
08-31-2008, 03:22 PM
1993 34' Excella
Estancia
, New Mexico
Roger
As I remember there are 2 capacitors. Careful you don't get zapped.
