Old 02-16-2016, 10:14 AM   #1
gaetannicole's Avatar
The best between 30 a surge protector
Hi everybody!
What this the best 30 amperes surge protector between TCT and Progressive Industries and why?
Thank you in advance for your answer.
gaetannicole is online now   Reply With Quote
Old 04-24-2016, 08:47 PM   #2
SeaAirstream's Avatar
2015 27' FB International
Puyallup , Washington
I have been researching and can not find some pro and con analysis. Did anyone ever respond to your post?
SeaAirstream is offline   Reply With Quote
Old 04-24-2016, 10:17 PM   #3
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
I have owned both and have settled on the Progressive unit, in part because it has a lifetime warranty vs a one year warranty on the TRC unit. Joe
jayseejay is offline   Reply With Quote
Old 04-24-2016, 11:07 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
A lifetime warranty is a very good thing.
Surge protectors have a limited lifespan, measured in joules (a joule is one watt-second). A surge protector rated for 1000 joules (for example) can survive ten 100-joule power surges, or two 500-joule surges, or one 1000-joule surge— and then it's nothing more than a very short but very expensive extension cord.
You will never know how many joules of energy there are in a single power surge, so some "authorities" on the subject will tell you to replace your surge protector after every surge. That gets prohibitively expensive very quickly. That's where the lifetime warranty comes in handy. With the lifetime warranty, you're not really paying for one surge protector, you're paying for a lifetime supply of surge protectors. But even so, get the surge protector with the highest rating in joules that you can afford. Because like I said, you will never know how big the surge will be.
For the record, a Progressive SSP-30 is rated for 1825 joules. A TRC surge protector is only rated for 1020 joules.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-25-2016, 11:53 PM   #5
Thank you for the insights
Old 04-26-2016, 12:25 AM   #6
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
These are like the sacrificial anodes put on out board motors. The anode deteriorates over time rather than the metal parts of the motor and drive shaft.
The Progressive Industries 30 and 50 amp surge protector and power monitoring systems can protect the entire trailer and have a lifetime warranty if they ever have to do their job and then need replacement.
I'm new. Need for surge protector? bcombs Member Introductions 14 11-09-2013 07:47 AM
1968 - Progressive Ind. 30 amp surge protector? Randy Gates 1965 - 1969 Globetrotter 13 10-17-2011 01:35 PM
Room for in-line surge protector in 23' Intl? Hoonanea Electrical - Systems, Generators, Batteries & Solar 0 10-03-2011 11:07 AM
Loud Humming Noise from Surge Protector Michigander Land Yacht/Legacy Motorhomes 8 07-23-2011 03:56 AM
surge protector pip8688 Batteries, Univolts, Converters & Inverters 15 08-09-2010 05:14 AM
