05-27-2007, 01:25 PM
1972 31' Sovereign
Haskell
, Oklahoma
testing the univolt
Forgive me if this question has been answered a thousand times, but, is there a simple way to test if the Univolt is charging my battery and if it is charging it correctly.
Flying Scot
05-27-2007, 02:31 PM
1978 31' Excella 500
Venice
Yes, put a voltmeter across the battery and check the voltage. Should be between 13.5 & 14.5 volts approx. with the univolt on.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
05-28-2007, 08:44 AM
Jupiter
My recent Univolt experience is it keeps known good battery at 14.08 VDC after a week on float, no over heating or bubbling, with only occasional 12V loads applied... No humming, no buzzing - just power...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
05-28-2007, 08:56 AM
1977 Argosy Minuet 6.0 Metre
Colorado Springs
Univolt, no hum, no buzz, What, is mine about to die? Buzz like crazy, won't be able to sleep in the coach with the blasted thing on. Would like to run this summer then replace next year. It does show between 13.5 and 14.5 volts across the battery, anytime I have checked it however. And the battery isn't losing any water.
Royce (K0RKK) 146.460 simplex
Web page https://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
05-28-2007, 09:06 AM
Jupiter
This is second trailer; 1st Univolt rumbled at 60Hz until it didn't anymore and I can tell you cooked Univolt smells peppery. I can see the blue fuse panel and wiring buried under the bathtub in back of closet but I don't hear any noise.
Ripple voltage is bad thing on batteries (voids warranty on AGMs) and there are three largish capacitors inside the Univolt so I wonder if checking them might reduce vibration & noise, I gleefully discarded them when I recycled the fuse panel off AS1...
05-29-2007, 07:38 AM
1972 31' Sovereign
Haskell
, Oklahoma
Excella CM, Thanks for the advice. Unfortunately, there was no increase in voltage across the battery with the Univolt on. I made sure the battery was Ok and able to take a charge. I checked all the fuses and breakers and they all checked out. Any ideas or is it time to go down the "replace the univolt" path.
05-29-2007, 09:56 AM
1974 25' Tradewind
Lake Oswego
, Oregon
Charge Wizard
When I had my new univolt installed the dealer sent me home with a 'Charge Wizard' and told me to hook it up the inverter. I haven't done so yet. I really don't understand what it does, but I am wondering if it would answer this question.... Pam
05-30-2007, 08:26 AM
1972 31' Sovereign
Haskell
, Oklahoma
Thanks everyone for the advice. Looks like I'll be going down the "How do you replace a Univolt" path
06-12-2007, 01:07 PM
Orange city
Maybe this can help you?
Just got a 1974 Sovereign and univolt is DOA. Very quiet though LOL. looks like I need to buy a new one. To hold me over till i can offord a new univolt I direct wired a battery charger to the fuse panel and set it to a 2 amp maintenance cycle. I have to use the 12volt dc very c onservatively. When I require more juice I simply switch the charger to 10 or 50 amp. But it gets the job done and keeps the battery happy. The amazing thing is that for how many years the trailer sat; the battery charged right up... go figure...
06-12-2007, 01:51 PM
1996 28' Excella
Okemos
, Michigan
For most inexpensive battery chargers, the 50 or 60 amp setting is for VERY short term use. It is meant to allow you to jump start your car with the charger. If you draw that much current for very long, it will get very hot and cook the charger.
Earlier a post mentioned the capacitors in the old univolts. They were to form a resonant circuit with the transformer, as these were known as ferroresonant converters. They were not filter capacitors, but they were the main cause of dead univolts. Replacing them can bring it back to life.
The best use for one of these is as a boat anchor. I replaced mine with a WFCO 3-stage converter and love the quiet power.
Dave
Okemos, MI
T.V.:'05 Dodge Ram 2500 4x4 Quad Cab Cummins
AIR#2276
06-12-2007, 03:21 PM
Orange city
response to sander17
thank you for your concern... you are correct the 50 amp setting is only a short time setting. The only setting I use ~continuosly~ is the 2amp. If i am going to use lots of pwer for a few min i switch over. But If I was not an electrician I would probobly blow my charger and battery up. ROFL! For anyone that may not know any better; Im glad you brought that up...
06-12-2007, 05:57 PM
Retired.
, At Large
Matt, your Univolt may still work. Check inside the mirrored medicine cabinet in your bathroom, you may find a black toggle switch. If it is "off", turn it on, and listen for the hum...If it hums, then check your battery voltage, with any luck, it will work.
06-12-2007, 09:41 PM
Orange city
Sorry Overlander63; no switch (I may not have seen it or it may be located somwhere else in my trailer) But thanks for the tip. I would have never looked there for any components... BTW I have been reading this site for awhile and have found many of your posts helpful....
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Univolt FACTS
smily |
Electrical - Systems, Generators, Batteries & Solar |
69 |
08-18-2005 11:47 PM |
Univolt Testing
Craig |
9 |
08-23-2002 09:13 AM |
1981 Airstream Excella Univolt
dienst1 |
Airstream Motorhome Forums |
1 |
08-20-2002 09:05 AM |
univolt III wiring
McGill |
0 |
07-05-2002 08:26 PM |
Univolt Operation
melprice |
11 |
06-17-2002 04:13 PM |
