Old 09-12-2008, 03:24 PM   #1
Turtle's Avatar
2004 16' International CCD
Arcata , California
Testing 7300 converter
I have an '04 16' CCD. The battery is not charging when hooked to shore power. Everything is working otherwise, air conditioner, etc. The Airstream manual says to test the converter by disconnecting the 12+ wire from the master switch and then check voltage output between heavy positive and negative wires coming out of the converter. My question is: What and where is the 12+ wire and what and where is the master switch? I don't want to short anything out here.
Thanks, Jamie
Turtle is offline   Reply With Quote
Old 09-12-2008, 05:17 PM   #2
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Jamie,
The 12 volt main disconnect on our '06 Classic is on the access door to the 12 volt fuse panel / converter. It is behind the drawer under our sofa. It is a big silver rotary switch. It only has two positions...ON and OFF. You need to turn the swith OFF and with a multi-meter test the output of the converter. Locate the converter and the terminals should be labeled "+" and "-". The "+" is the heavy RED wire and the "-" is white, I think.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 09-12-2008, 05:25 PM   #3
DEITZ645's Avatar
Jamie,
Your 12 volt master disconnect should look something like this, but probably not exactly...
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 09-12-2008, 06:39 PM   #4
Turtle's Avatar
Arcata , California
Oops! My bad. It was a blown 30 amp fuse. It's usually the simplest answer. Thanks for the input though. Jamie
Old 09-13-2008, 06:00 AM   #5
DEITZ645's Avatar
Jamie,
Always start simple and then work towards the complicated. Just glad you isolated your problem. Were you able to locate your 12 volt main disconnect switch?
In any 12 volt system problem always suspect a bad ground or ground fault, a blown fuse, or a short. Those are the three big gottcha's when dealing with 12 volt systems.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 09-13-2008, 09:30 AM   #6
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Now for the million dollar question...what made a 30A fuse blow?
Uwe
www.area63productions.com
Converter testing yukionna Electrical - Systems, Generators, Batteries & Solar 11 07-29-2008 08:13 PM
Magnetek 7300 intallation Craig Murphy Batteries, Univolts, Converters & Inverters 4 03-17-2008 06:16 PM
Testing Canuks 2002 - 2005 International 10 03-17-2005 07:30 AM
7300 series converter dhe9 1997 - 2004 Bambi 1 10-15-2004 04:38 PM
