Old 06-05-2015, 09:38 AM   #1
2017 19' Flying Cloud
Madison , Wisconsin
Send a message via AIM to jtwind Send a message via MSN to jtwind Send a message via Yahoo to jtwind
Systems Monitor Faceplate
Not sure where to put this. Have a 2014 Bambi, monitor works fine but the faceplate is supposed to fit into insets in the housing or frame. It doesn't, it's crooked by a bit. If twisted to correct spot it just twists back. Not a major issue just cosmetic, mentioned this to the tech when I was in for warranty stuff and he wasn't any help. So, ideas? Does anyone know how the faceplate/insert is held in. Just clips? I will try and fix myself but would like to know what's supposed to holding it in before I start prying or pulling? Thanks
jtwind is offline   Reply With Quote
Old 06-05-2015, 09:45 AM   #2
dznf0g's Avatar
Oswego , Illinois
Micropulse?
If so, the plastic faceplate insert just prys out. Use something that won't gouge the plastic. Then you will see screws which hold the base to the wall.
-Rich-
Systems Monitor BigGrey Electrical - Systems, Generators, Batteries & Solar 4 07-18-2012 04:33 PM
Micro Pulse Probeless Systems Monitor - How to Operate Colonial Airstream Commercial Listings 7 01-05-2012 08:28 AM
Tire Pressure Monitor Systems Bluto Tires 68 09-21-2011 06:59 PM
Micro-Pulse Systems Monitor Bites the Dust Wayne&Sam General Repair Forum 22 08-25-2011 08:04 AM
Systems monitor Jack46 2006 - 2010 International 4 05-20-2008 08:06 PM
