Old 05-24-2010, 08:10 AM   #1
Zugbug's Avatar
Volcano , California
switching to group 27
I have a 2006 23' and would like to switch from the group 24 batteries that came with the unit to group 27. Has anyone done this and how did you modify the battery box?
Zugbug
2006 23' Safari
2006 F-150
Zugbug is offline   Reply With Quote
Old 05-24-2010, 08:42 AM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Several have done this sucessfully. Have you tried searching the threads?
Michelle TAC MT-0
Sarah, Snowball
Old 05-24-2010, 10:26 AM   #3
Zugbug's Avatar
Yes I have look through some of the posts, but I haven't found anything on having to modify the battery box. There was one thread that stated there are some group 27's that will fit into the existing box anyone know which models those are?
Zugbug
2006 23' Safari
2006 F-150
Old 05-24-2010, 02:23 PM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
It's not so much in modifying the batter box, the tray that is in the box will only fit a 24. IIRC, you simply have to remove the tray at the bottom and the 27s will fit with a bit of finesse*.
*provided your battery box is the same as the one on my 2004
Old 05-24-2010, 03:51 PM   #5
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Don't forget that the battery boxes are sealed and vents to the outside. If you are using wet cell batteries any disturbance to the box allowing the batteries to vent inside will result in fumes being let into the living compartment, NG. Airstream may have replacement boxes to accomodate the larger size of battery.
Hope this is of some help.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 05-24-2010, 03:58 PM   #6
_
23 safari has the wet cells OUTSIDE on the tongue...
many threads on the variety of tweaks,
here are just a few...
http://www.airforums.com/forums/f449...7-a-46804.html
http://www.airforums.com/forums/f449...lts-64324.html
http://www.airforums.com/forums/f449...ing-64137.html
http://www.airforums.com/forums/f449...2-a-31854.html
http://www.airforums.com/forums/f449...ity-38012.html
http://www.airforums.com/forums/f449...rum-47378.html
each type of tweak is battery dimension AND box/A frame dimension specific.
seems part of the reason for the 2x6v switch is ONLY the height (lid) changes..
while 24 to 27 involves L times W issues.
get the measurements and dimensions and space restrictions...
and start doodling.
cheers
2air'
Old 05-24-2010, 07:51 PM   #7
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
I did the change and merely bought a new battery box.
Ahab is offline   Reply With Quote
Help-Group 31S vs Group 27 Battery Question trevisgardne Batteries, Univolts, Converters & Inverters 4 06-10-2009 08:32 AM
NOTICE: Switching to a new network Andy R Forum Admin, News and Member Account Info 23 08-26-2007 04:39 PM
Switching out cabinets dogstayplay General Interior Topics 5 04-05-2005 09:23 AM
need opinion - switching out tanks kbryner1 LP Gas, Piping, Tanks & Regulators 7 05-24-2004 08:06 PM
Switching to Diesel? silverback On The Road... 44 11-25-2003 01:30 PM
