Old 08-05-2010, 10:14 AM   #15
2011 28' INTERNATIONAL
2010 28' International
Campbell , California
I found the problem. Of course it was after I pulled out all the outlets(everything looked fine) In the RV the neutral and ground are not to be bonded. However, I also have an inverter that bonds neutral and ground together. Outlet power is routed thru a switch that I can select either inverter power or shore power from the converter. Here, the hot wires are on connected to the switch, but the neutral and ground are connected to each other, thus the neutral and ground become bonded for the entire RV due to the inverter. As soon as I disconnected the inverter neutral, everything was happy. Now I just need to figure out how I can route the neutral thru a switch as well to keep them separated. Is there a switch that I can get that can switch 2 wires at a time(hot and neutral)?
pip8688 is offline   Reply With Quote
Old 08-09-2010, 05:14 AM   #16
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Glad you found the problem. I don't know enough about electricity to do any kind of trouble shooting myself.
Thanks for sharing.
Family of Disney Fanatics
WBCCI# 4821
Segment Protector install equigley 1969 - 1973 Safari 3 02-07-2015 07:05 AM
I'm new. Need for surge protector? bcombs Member Introductions 14 11-09-2013 07:47 AM
Segment protector ticki2 Rock Guards, Segment & Window Protectors 4 10-21-2008 05:53 PM
Segment Protector install equigley Rock Guards, Segment & Window Protectors 7 12-07-2007 05:03 PM
Protector of the frame ArtStream Repairing/Replacing Floor &/or Frame 0 08-14-2006 01:32 PM
