Old 04-24-2011, 09:32 AM   #1
greatlakes's Avatar
2004 25' Safari
N/A , Michigan/Florida
Storing Trailer Without Batteries
Can any harm come to any trailer system by removing the batteries for a couple of months' storage? The batteries will be stored at the house with a trickle charger and checked often.
___________________
Frank
2004 25' Safari
2010 4x4 Ford EB Expedition
greatlakes is offline   Reply With Quote
Old 04-24-2011, 09:41 AM   #2
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
I do that every winter. It will be fine.
Get involved and sign up for a Rally!
https://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 04-24-2011, 09:49 AM   #3
Mexray's Avatar
1978 28' Ambassador
Morada , California
That's the best way to do it...your batteries will have a longer service live, and you'll have the opportunity to see that the connections are clean and tight each 'season'...
Ray & Pat; Morada, CA
Old 04-24-2011, 09:54 AM   #4
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Thats the way I have been doing it since we have had the trailer. I take them down the basement and put them on a board(optional) and put the trickel charge on them. These Batteries are now (not sure) 3 or 4 years old and no problems. I check them once a month for water when they are in the trailer. I am still using the old charging system that came in the trailer in 1977. Although I would like to rebuild that charger because of a hum that Im getting in the radio. I am sure the filter capaiators are about shot. I have not been able to come up with a schematic for it yet,no one seems to have one.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 04-24-2011, 10:09 AM   #5
au_ee's Avatar
2007 31' Classic
Pulaski , Tennessee
This is the best way to store them during the off season. You might want to avoid setting them on concrete. I did that one year and it discolored the concrete where they were sitting.
Steve & Beth
TAC AL-4
AIR 22763
07' Classic 31, 11' Dodge 3500 Cummins
au_ee is offline   Reply With Quote
Old 04-24-2011, 11:04 AM   #6
greatlakes's Avatar
2004 25' Safari
Thank you all for the reassurance.
I keep them on a handcart with a woodden base in the garage and connected in parallel. Trickle charger with pos lead on one battery and neg on the other.
___________________
Frank
2004 25' Safari
Old 04-24-2011, 12:23 PM   #7
1975 29' Ambassador
Reno , Nevada
Discolored the concrete? That should not happen with modern battery cases.
Trickle charge is fifty year old technology for battery maintenance. Use a modern battery maintainer that will maintain a full charge yet avoid plate corrosion and will also implement a sulfation inhibiting technique.
If you use a modern converter in your rig such as the WFCO or the Intellipower with chargewizard, you should not need to do more than make sure the rig is plugged in when not in use and check electrolyte levels every six months or so.
Truck & Trailer Weights nickmeloy Towing, Tow Vehicles & Hitches 6 04-02-2014 10:02 AM
Motorhomes, and Charging Batteries.... Keyair General Motorhome Topics 18 10-15-2011 08:21 AM
Batteries lost water/electrolyte blickcd Batteries, Univolts, Converters & Inverters 13 03-28-2011 08:26 AM
How do you deal with your trailer while exploring? mikescha On The Road... 18 02-21-2011 11:36 AM
A sad end to a wonderful trailer rmk110761 Airstream History 9 02-15-2011 09:12 AM
