Old 11-04-2019, 11:53 AM   #1
Storing Bambi 22FB
Hey all. Storing our beloved new Bambi 22FB for the winter tomorrow. It will be inside but without shore power. I will therefore remove the batteries. Questions:
-If I remove the batteries before leaving home for the storage facility, will the trailer exterior lights and power jack function when hooked up to the TV? Or should I just remove them when parked for the winter at the facility?
-Aside from putting the battery disconnect to store, is there anything I need to do prior to disconnecting? Can I leave the solar panels plugged into the controller?
Thanks in advance for the info.
steilkurve is offline   Reply With Quote
Old 11-08-2019, 11:27 PM   #2
2011 22' Sport
Portland , Oregon
You cannot legally tow without the battery installed, as it disconnects the break away brakes...those require onboard batteries. Your jack will also not work.
SilverHouseDreams is offline   Reply With Quote
Old 11-09-2019, 10:19 AM   #3
I’d just disconnect one lead on the battery and leave it in. Then reconnect to tow.
Kanusport is offline   Reply With Quote
Old 11-10-2019, 08:24 AM   #4
Thanks. I ended up leaving the batteries in until I stored the AS at the facility. There, I took five minutes to detach them and replace the cover. The batteries are now in my garage elevated and plugged in to a Noco battery charger/maintainer.
storing a portable grey table container in am AS 22FB-solution found waninae39 2005 and newer - Bambi all models 19 09-25-2017 08:32 PM
22FB Bambi SPort into shipping container sltsmith Airstream Trailer Forums 5 01-17-2013 03:36 AM
2012 Bambi Sport 22FB ? PaulG_4307 2005 and newer - Bambi all models 2 06-09-2012 02:08 PM
Towing a Bambi 22FB with a 2007 Tacoma krusty Tow Vehicles 15 01-16-2012 11:06 PM
Storing a Bambi over Winter campadk 2005 and newer - Bambi all models 1 07-17-2006 04:37 PM
