Old 10-13-2016, 02:04 PM   #1
dasams's Avatar
Marin , California
Stinking Batteries Smell Like Rotten Eggs
My wife and I picked up our 2017 FC 25 on Aug 15 and have been traveling with it full time. We have yet to use the batteries since we've been on shore power each night.
A few days ago, we started to smell rotten eggs and traced the odor to the battery box. Over the course of a day, the odor got really nasty and we switched the batteries to the 'store' position and the odor went away. Fast forward to today, the odor came back so I switched them back to the store position and the odor is dissipating.
Has my Parallax unit cooked the batteries? The date stamps on the Interstate batteries are May, 2016. I'm taking the rig to the Interstate dealer tomorrow and will post the outcome.
Thanks, Dave
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
dasams is offline   Reply With Quote
Old 10-13-2016, 02:10 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
They are sulfated from overvoltage charging. Check the water level if possible and standing voltage. Might plan on making a warranty appointment to have it checked out.
MICHAEL
Old 10-13-2016, 02:34 PM   #3
dasams's Avatar
Marin , California
I measured the voltage at 12.75V. I pulled all four caps and the water level in 11 of the cells looks normal. The twelfth looks like it contains a honey colored solid and the level is just slightly below normal.
We are driving through St George tomorrow where there's an Interstate Battery warehouse. I talked to the tech who will look at the batteries and replace under warranty if they are defective.
Could the Parallax be at fault? The fan seems to be on about 20% of the time. Is this excessive?
Dave
2018 FC 27 FB
2017 FC 25 RB Gone
Old 10-13-2016, 03:17 PM   #4
TheDuke's Avatar
2016 30' Classic
The Beautiful Mountains Of Southwest , Virginia
Images: 68
Lp?
Since they are right below the LP tanks, you could possibly have a LP leak? That smells much like what you are describing as a "rotten egg" smell.
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Wayne - "JB Books" 1976.
TheDuke is offline   Reply With Quote
Old 10-13-2016, 03:25 PM   #5
AWCHIEF's Avatar
Images: 33
Sounds like you might have at last one dead cell. They can verify that when tested.
MICHAEL
Old 10-13-2016, 03:31 PM   #6
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Rotten eggs smell is likely hydrogen sulfide, and that is dangerous. Recently a woman and her daughter were found dead inside a running SUV on the Florida turnpike. The cause of death was determined to be hydrogen sulfide poisoning from a defective battery which was apparently mounted under the car seat.
Get this looked at and corrected ASAP.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 10-13-2016, 04:39 PM   #7
Cruiser6483's Avatar
1954 25' Cruiser
Bern - Thun , Berner Oberland
Images: 31
For 2 years I reconstruct my Cruiser 1954. A few weeks ago I noticed a strange smell in the trailer. Somewhere dead animals in a cavity?
Finally, the stench was so horrible that I could no longer work in it. Together with my neighbor, we went in search. Incredibly, it was the new gel battery, a large 250 ah, which should be free of maintenance! All around and above were large bulges, she was at bursting.
My Garagist has then substituted ...
Greetings from the Swiss mountains - Werner
Cruiser6483 is offline   Reply With Quote
Old 10-13-2016, 06:37 PM   #8
New Borockton , Alabama
Images: 21
We send a lot of 4 stage upgrades for the Parallax units to dealerships every day, and not just Airstream. It's widely believed/known they are not your battery's best friend but some folks nurse them (Parallax) along and monitor them closely and get by for awhile, even a couple years before buying new batteries. The rotten egg smell is likely your batteries because propane smells like...well...propane.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 10-14-2016, 11:13 AM   #9
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Propane smells like rotten eggs also, because 'they' add Methyl-Mercaptan to the gas as an indicator.
MelGoddard is offline   Reply With Quote
Old 10-14-2016, 11:49 AM   #10
gainesville , Virginia
  • Natural gas and propane are colorless and odorless, hence a small amount of methyl mercaptan or ethyl mercaptan is always added to make it easy to detect a gas leak. The odor is reminiscent of rotten cabbage or a skunk and may get noticeably stronger as the tank becomes more empty with use, as the mercaptan is heavier, letting one know it's getting near time for a refill.
Carry On!
Gary
GEEEER is offline   Reply With Quote
Old 10-14-2016, 11:54 AM   #11
coveredwagon's Avatar
LOS ANGELES , California
Your battery is fried. Get a new one. Same thing happened to me.
coveredwagon is offline   Reply With Quote
Old 10-14-2016, 12:41 PM   #12
Wise Elder
Jammer's Avatar
2010 30' Classic
You have a shorted cell. Because the cell is shorted, the remaining cells are overcharging. The battery could overheat or explode if you continue to use it in this condition.
Good luck. You'll need it.
There are many drawbacks to the Parallax chargers, among them the loud fan, but I doubt if it has anything to do with your problem.
Shorted cells can be caused by allowing the electrolyte level to get below the tops of the cells, by manufacturing defects, or by age.
Old 10-14-2016, 02:23 PM   #13
Images: 21
You're correct Mel I just meant that they smell different to me.
Old 10-14-2016, 06:25 PM   #14
dasams's Avatar
Marin , California
Bingo!
We stopped at Interstate Battery in St George today and the tech (Alan) was awesome. He pulled the battery, confirmed the shorted cell and dropped in a new battery. All in about 30 min. He also explained that the honey colored solid was the strap holding the cells together and isn't normally visible with a proper water level.
Thanks for all the comments, Dave
2018 FC 27 FB
2017 FC 25 RB Gone
Where to move batteries inside 23d. Upgrading to AGM batteries. Eyeballs Electrical - Systems, Generators, Batteries & Solar 36 03-08-2018 07:08 PM
West Boondocking with your "stinking" Dog Ray Eklund Boondocking 33 12-04-2015 03:18 AM
Trailer Batteries 83Excella Electrical - Systems, Generators, Batteries & Solar 8 02-04-2013 10:57 PM
2 batteries outside and two batteries inside timmaah Electrical - Systems, Generators, Batteries & Solar 14 08-25-2011 07:18 AM
Batteries..All about batteries FrankR Batteries, Univolts, Converters & Inverters 0 07-17-2002 09:05 PM
