Old 10-14-2016, 07:01 PM   #15
New Borockton , Alabama
Images: 21
Good to hear they took care of you. I don't think Interstates are necessarily bad batteries and I run them in a couple of my vehicles. You can prevent it from happening again if you ditch that single stage Parallax 'battery boiler' as they are known in the industry. At a minimum, get one of those automatic watering gizmos. I think most RV dealerships carry them.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 10-14-2016, 07:34 PM   #16
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I have been using the original chargers since 1973 with my avion, and in my airstreams and haven't had any battery troubles, just check the water level 2 or 3 times a year...most have averaged 6 years.. Not so bad...
Old 10-15-2016, 05:36 AM   #17
Originally Posted by dasams View Post
Could the Parallax be at fault? The fan seems to be on about 20% of the time. Is this excessive?
Dave
I don't know your exact set-up or model number, but I will tell you that our Parallax unit failed this year and darned near burned down our rig. Our battery began to cook because of it, but we caught it in time before it was totally destroyed.
The failure was traced to a short circuit, and Parallax admitted to us that it was the fault of their product. Because it was still under warranty, we shipped it back to them so that they could diagnose whether a they were obligated to replace it at no charge, which they did. They also told us that they'd seen a few other similar failures in the product.
You can read more detail in this Air Forums post and see if there's possibly a correspondence to your own situation. Good luck with it.
Old 10-15-2016, 10:03 AM   #18
dasams's Avatar
Marin , California
Our 2017 FC 25 has a Parallax 8355 that I believe is a standard install. I still don't know if this is considered a 'smart' charger or a trickle charger.
You can read more detail in [URL="http://www.airforums.com/forums/f240/advisory-electrical-converter-failure-hazards-147671.html"]
Thanks for sharing.
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
dasams is offline   Reply With Quote
Old 10-18-2016, 10:27 PM   #19
Images: 21
The 8355 is not a "Smart Charger" or a trickle charger. It is a single stage converter/charger with a constant 13.8 VDC output that can overcharge.
Where to move batteries inside 23d. Upgrading to AGM batteries. Eyeballs Electrical - Systems, Generators, Batteries & Solar 36 03-08-2018 07:08 PM
West Boondocking with your "stinking" Dog Ray Eklund Boondocking 33 12-04-2015 03:18 AM
Trailer Batteries 83Excella Electrical - Systems, Generators, Batteries & Solar 8 02-04-2013 10:57 PM
2 batteries outside and two batteries inside timmaah Electrical - Systems, Generators, Batteries & Solar 14 08-25-2011 07:18 AM
Batteries..All about batteries FrankR Batteries, Univolts, Converters & Inverters 0 07-17-2002 09:05 PM
