Old 06-10-2010, 10:35 AM   #15
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Stephen
I guess I would lean toward replacing the converter with the same size as your original univolt. If this is 70 amps then you can get a 70 amp 9200 series Progressive Dynamics Converter from Best Converters for about $203 including the remote pendant. This is about $50 less than the 80 amp model plus it is lighter and smaller.
I am curious why AS would install a 70 amp converter, when Byanl says that anything over 40 amps could be harmful (did I misinterpret something?). Normally the manufacturer's tend to go on the adequate (cheap) side whenever possible.
Dan
Old 06-10-2010, 10:43 AM   #16
2005 22' International CCD
Aliso Viejo , California
I just removed the three Blue Top optimas in my trailer a couple of weeks ago. My results were similiar to SafariSS. Very weak. I replaced all three with Lifelines which is a huge improvement. There is a place in Texas that has by far the best price on the Lifelines. I can find it tomorrow when I get home from this trip.
Davern1 is offline   Reply With Quote
Old 06-10-2010, 11:50 AM   #17
Mexray's Avatar
1978 28' Ambassador
Morada , California
Davern1...here's another way to look at it...
BT Optima = 55 AH
Lifeline GP-24 = 80 AH
You'd have to add another BT for a total of (4) batteries to get about the same AH capacity as your three new Lifelines...!
Optima's are good batteries, don't get me wrong, they're just not suited for RV deep cycle (house) use due to their limited AH rating...IMHO!
Ray
Ray & Pat; Morada, CA
Old 06-10-2010, 02:47 PM   #18
stephenh2's Avatar
Tyler , Texas
Well, I ordered the 9270 from www.bestconverter.com today. I ordered a new fuse block with it, too. I decided not to risk any new battery on the old Univolt, and certainly not a new flat screen tv or dvd player on it. We like our gadgets and to protect them I'll change out the converter and buy a decent flooded deep cycle for the time being. I'll learn what I can about care and maintnance of a 12v system before I spend the big bucks on a battery.
Thanks for the input, I'll be back to this subject if I have any questions on replacing the Univolt.
Stephen
Home again in Tyler, Texas
Please visit any time!
stephenh2 is offline   Reply With Quote
Old 06-10-2010, 05:31 PM   #19
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I think you did the right thing(s), Stephen.
I'll be watching your progress.
Vaughan
Old 06-10-2010, 06:58 PM   #20
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Some new converters work better with AGMs than others. Code says AGM batteries need venting. Personally I don't.
Old 09-09-2011, 04:51 PM   #21
JBinKC's Avatar
2007 31' Classic
Kansas City , Missouri
The Progressive Dynamics converters are now 4-stage. Anyone installed one of the new ones? The Intelli-Power 4600 Series Upgrade or Replacement RV Converter/Charger with built-in Charge Wizard is the Brand of choice by leading RV manufacturers.
JBinKC is offline   Reply With Quote
Old 09-09-2011, 05:53 PM   #22
1974 Argosy 20
Kooskia , Idaho
Originally Posted by JBinKC View Post
If you look at the PD website, the "4 stage" is simply a re badging of the old
"3 stage" unit. The three stage one had an additional "equalize" mode every 15 hours or so, the new one calls that a "stage" and has changed the name to a "desulficaton" stage, but it has exactly the same specs as the old one for that "stage". So, no need to change at all.
Old 09-09-2011, 06:56 PM   #23
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
[QUOTE=stephenh2;858601
2. Is the blue top a decent value for the money? thanks,
Stephen[/QUOTE]
Stephen,
IMHO......NO! The grp 27 Blu top has only a 67ah rating. Better off with a conventional wet cell deep cycle Marine/RV.
Have had good luck with Interstate and Die Hard, both readily available.
Or jump in with both feet and go Lifelines and IOTA IQ4 converter.....
Sweet Streams....
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
How much will you spend this year? Andy R Community Polls 76 02-01-2009 08:22 AM
place to spend winter briandg On The Road... 5 08-05-2008 08:16 PM
What else do you spend your money on? Ultradog Off Topic Forum 42 04-16-2006 08:20 AM
Here's your chance to spend someone else's money. guy99 Mechanics Corner - Engines, Transmission & More... 27 03-04-2006 12:46 PM
How much did you spend restoring your AS? Boondocker Our Community 24 09-06-2005 05:26 PM
