Old 01-05-2008, 07:56 PM   #1
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Sources for 12 volt distribution
Hey folks,
Need a little advice. It seems that I need to replace my 12 volt distribution panel with a new one. It seems that the plastic on the old panel has shrunken/cracked and the rivets that hold the fuse holder together are loose creating bad connections.
Where is a good source to find a new panel?
Here are pictures of the old panels. I would also like to change out the other small panel that has fuses for all the other 12 volt sources for the umbillical cord. I would like to use ATC automotive type fuses if possible.
crispyboy is offline   Reply With Quote
Old 01-05-2008, 08:46 PM   #2
2005 28' Safari
Mono City , California
Take a look at Cole Hersee Co.. They may have what you are looking for. Most heavy-duty truck or off-road equipment parts suppliers stock or can order from Cole Hersee.
Hope this helps you out.
TBSarfari28 is offline   Reply With Quote
Old 01-05-2008, 09:35 PM   #3
I found the ones for our airstream motorhome at O'Reillys. They have the newer style with the plastic plug in fuses. Price was very reasonable.
We had the same problems you did with the rivets coming loose and causing all kinds of problems.
Good luck!
Old 01-05-2008, 09:46 PM   #4
azflycaster's Avatar
1975 25' Tradewind
Dewey , Arizona
Images: 62
Randy - 68 Overlander sells them at his site also.
Circuit Breakers and Fuses
Richard
Old 01-07-2008, 02:50 PM   #5
crispyboy's Avatar
1994 30' Excella
The attached picture of the distribution board was recommended as a replacement because it has a 30 amp circuit capability.
What type of insulating material would one use between the board and the mounting surface?
12 volt
Tank adapter sources? PoconoAir Waste Systems, Tanks & Totes 8 07-09-2007 06:11 PM
Interior Lighting Sources Janets Husband Electrical - Systems, Generators, Batteries & Solar 14 01-15-2007 08:03 PM
6 volt vs 12 volt brakes? lwebb Brakes & Brake Controllers 17 07-14-2005 09:32 AM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 01:04 AM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 10:03 AM
