Old 10-15-2015, 01:42 PM   #1
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
Sometimes I feel like a Motherless child...
So I am replacing the converter, moving from the parellax single stage to the PD 4655. I've read the threads, watched the videos, budgeted 2.5 hours of time and gone over to my 27 FC with tools and the new converter. I'm stoked, and pumped to get this done.
OK, the first thing is to take off the access cover of the old converter. Umm. The screws that hold the cover on seem to be torx or star or something. None of my Allen keys will turn them. Well #%%*! There goes my window of time for the day. Guess I'll try this weekend.
Anyone know what size bit fits those stupid screws?
Mike
Caffeinated is offline   Reply With Quote
Old 10-15-2015, 02:03 PM   #2
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . the ones on mine are torx., buy at any hdwe / auto parts store.............have you ever considered Decaf ? regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 10-15-2015, 02:56 PM   #3
z , North Carolina
Well
Caffeine,
Thanks for the heads up on the screws. Fortunately, I have a set of those in the ol toolbox. I am about to order the exact same unit. Everything I have read & watched on YouTube indicates this should be a very easy project. I will be doing the same thing as you next weekend. I hope yours goes smoothly. I have heard nothing but good things about that unit, and that everything comes with the kit. Hope you bought yours from Randy at bestconverter.com. He's a pretty knowledgeable guy.
Good luck, and let us know how long it actually takes you.
Sea ya down the road,
Gavin
FishinHatteras is offline   Reply With Quote
Old 10-15-2015, 02:57 PM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Ha!
2012 Dodge Durango Hemi/AWD
Old 10-15-2015, 04:27 PM   #5
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
Caffeinated; Fishin - keep us posted, with Pics if possible. This is in our future as well.
The Ice Man is offline   Reply With Quote
Old 10-16-2015, 11:56 AM   #6
2007 25' Safari SS SE
Crowley , Texas
Time for me to do this upgrade too. Baby-ing the yellow tops has really gotten old. I'm sitting pretty in torx bits. My guess is bit size is T5 or T7 but don't know for sure Let me know, Mike, and I'll mail you a full set- in the likely event AZ and HD are sold out. So, what I need now is to order the new converter. Bestconverter.com, here I come.
Best regards and best of luck to each of you.
George in Crowley.
TopGeorge is offline   Reply With Quote
Old 10-16-2015, 01:30 PM   #7
Crowley , Texas
Crikey. I meant to guess T-15 or T-17. Sorry.
Old 10-16-2015, 09:30 PM   #8
Portland , Oregon
According to the Portland dealer, the screws are T-20. Which I have but didn't bring to the trailer originally. I'll find out for sure tomorrow.
Mike
Old 10-16-2015, 10:11 PM   #9
lewster's Avatar
Naples, FL , Hood River, OR
Haven't seen the video, but this mod usually takes me around an hour. There are several things to watch for:
be certain to remove the battery terminals (negative first) BEFORE you do anything else.
be certain that you are NOT PLUGGED IN to shore power
it is very beneficial to have a bit of additional length for the DC wire bundle. They are held by a retainer accessible at the back of the fuse block AFTER you remove the converter frame from the wall. You can put the cable bundle back to it's original spot after you're done.
the converter power hot lead (black) is wire nutted to the bedroom circuit hot and has a third wire leading to the breaker. I have never seen anyone use a wire nut within a breaker box except Airstream. Airstream does this to allow 2 circuits to be controlled by a single breaker, because it is against NEC code to place 2 wires into a single breaker. It would be a much better arrangement to simply add a double breaker in the space to allow each of the circuits to have their own breaker.
Other than that, it should be a less than 6-pack install.
Old 10-17-2015, 05:01 AM   #10
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Time for conversion
As is almost always the case when i do something for the first time, it takes for ever. I suspect I spent four or five hours from start to finish, including the planning stages for this conversion.
http://www.airforums.com/forums/f449...-126429-6.html
I like to double check/triple check as failures do to my error are not acceptable in a situation where I may be out in the boonies...
Happy trails and Good Luck
AIR #31871 WBAC #4165 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 10-17-2015, 06:51 AM   #11
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Less than a 6 pack install, ha! Good one Lew.
I was going to mention to Caffinated, that the moment without the right tool, is why you keep cold brews in the fridge.
Good luck with your install.
I got to practice that job three times as they sent mt two units that buzzed too loudly right out of the box. I got quicker by the third install
tevake is offline   Reply With Quote
Old 10-17-2015, 07:31 AM   #12
Portland , Oregon
I'm hoping that I only get the joy of replacing it the one time, but we will see. Fingers crossed.
And Lew, thanks for the tips.
Mike
Old 10-17-2015, 10:50 AM   #13
richw46's Avatar
Lexington , Kentucky
I did mine in the storage lot using my battery powered tools. I had already purchased a small pack of Torx drivers for my electric screwdriver. It took about an hour from start to end, just 2 beers (had to drive home ya know).
The instructions were very clear and the only problems I had were
1. One of the battery wires was short but I was able to pull it another inch or so to make the connection
2. The door doesn't completely close, had to force it a little bit. I didn't have a file with me, I'll do that on the next outing if I remember. It's just a little tight on closing it but a very, very small issue.
It is so much better now, showing proper charging amounts and holding it at 12.7. I'm very pleased with the swap out.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 10-17-2015, 10:59 AM   #14
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
I did this one too. I took pictures and notes on the wire hook ups. It helped me for sure. I did it while in storage and in two shifts of about an hour or so each. It was easy with reference pics and notes.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
sometimes works,sometimes doesn't! cmreumund Lights - Interior & Exterior 8 03-17-2009 07:10 AM
Feel like we've joined a cult! Ken & Janice Member Introductions 13 08-06-2006 08:57 AM
I feel like I'm living in Ground Zero jcanavera Our Community 14 04-10-2006 07:02 AM
I feel like such an Idiot.... Pick Steps 3 10-24-2002 12:59 AM
