10-17-2016, 07:03 AM
2003 30' Classic
Centerville
, Ohio
Solar trickle Charge
I would like to install/attach a small solar trickle charger that can be placed on the ground outside my storage building to trickle charge the batteries. Anyone ever done that?
How is it hooked up, etc?
Phil and Kathy Sinewe
2003 30' Classic W/Hensley Arrow
2014 F-150
Centerville, OH
10-17-2016, 07:09 AM
Naples
Hi Phil,
Welcome!
Many have done this and one of the systems that I have recommended to many folks is the 15 watt system from BatteryMinder. This is a complete system that comes with the 15 watt solar panel, solar charge controller and all required wiring and battery attachments.
It is definitely worth a look! http://www.northerntool.com/shop/too...8565_200328565
lewster
10-17-2016, 09:50 AM
2003 30' Classic
Centerville
, Ohio
So, if you are a dual battery, how is this hooked up?
2014 F-150
Centerville, OH
10-17-2016, 10:11 AM
2012 25' FB International
Trent Woods
, North Carolina
No doubt your batteries are in parallel, meaning the positives are connected together and the negatives are connected together. So, it does not matter as long as you connect the positive of your solar charger to a positive and the same for the negative.
Larry
10-17-2016, 10:17 AM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Originally Posted by lewster
Hi Phil,
Welcome!
Looks good; is it similar to the Zamp unit as well?
10-17-2016, 06:49 PM
New Borockton
, Alabama
The Zamp is going to be a much more capable system than the Battery minder and will actually charge and maintain should you need a real charge. Our experience with the Battery minders is that they will maintain, but struggle to really fully charge unless conditions are perfect and the small 15 Watt panel is well, is what it is. There really is nothing batter than an American manufactured Zamp product but by all means, compare and contrast them. Compare them both for sure but if you get a Zamp, you really have a portable solar charger you can take with you for other times or applications.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
11-03-2016, 07:15 AM
2003 30' Classic
Centerville
, Ohio
The Connection followup
Seems to me that I could wire the solar charger so you just plug it into the trailer with the 7 way plug. That would work, correct? Using the 12 volt and ground connection in a new male connector.
2014 F-150
Centerville, OH
11-03-2016, 11:16 AM
Oswego
Phil,
At your latitude, I think 15W is very marginal to keep two batteries charged up in the winter. I had a 15 watt system and it had a very hard time maintaining the batts in the extended gray days of winter.
I upgraded to a rooftop 100 watt panel (in parallel with a 160 watt Zamp portable, when needed), so I don't use a "trickle" system anymore. I would recommend a minimum of 25 watts...and would prefer 50 watts.
-Rich-
11-03-2016, 11:23 AM
2015 30' Classic
Pleasanton
Yes, you could connect your solar charger to a male 7-way plug.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
