Old 07-12-2007, 10:20 AM   #1
Devils Lake , North Dakota
Small Positive Battery Lead
In pulling the shot battery from the Argosy I noticed that the positive (red) lead is pretty small in diameter compared to a car. Maybe a 1/4" or less. Looks like 8 gauge or so.
Should this be larger gauge?? Like 4 gauge?
Sundance is offline   Reply With Quote
Old 07-12-2007, 10:31 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
You don't really need anything as large as a car battery cable (4 AWG) for an Airstream. 8 AWG is capable of handling 55 amps, which is more tha you will ever draw in your trailer on DC. My '06 CCD also has 8 guage cabling from the batteries. Your car needs the larger capacity cabling to provide a large burst of amperage for your starter motor.
No worries! Just be sure that the cable is in good condition and that no corrosion is present upstream from the end fittings. If there is corrosion present, you might want to consider replacing the cables with new ones that have heat shrink seals on the ends.
Also, be sure that all of your battery connections are clean and tight as loose or corroded connections will create loss of voltage flow and will create heat at the terminals and possible arcing.
Old 07-12-2007, 12:19 PM   #3
Thanks for the info Lew
TV Antenna lead fdx753 Audio, Video & TV 14 04-27-2004 08:45 PM
What type of battery should we get? Anna Electrical - Systems, Generators, Batteries & Solar 3 11-26-2002 10:23 AM
Battery Monitor Les Gilliam Electrical - Systems, Generators, Batteries & Solar 11 10-07-2002 08:13 AM
Battery Storage JAG Electrical - Systems, Generators, Batteries & Solar 2 07-05-2002 02:06 PM
Towing a small 60s trailer with a SUV... Andy R Tow Vehicles 15 03-30-2002 07:57 PM
