08-18-2008, 08:55 AM
1977 31' Sovereign
Manchester
, New Hampshire
Simple question about low voltage dis panel schematic?
I disconnected the charge line from the TV to the trailer because of wiring problems upon looking at the schematic I notices it says Hoist what would that mean?
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
08-18-2008, 09:05 AM
Princeton
, New Jersey
Please give a bit more information as to what your question is. Your attachment was for a 3M fire stop. What does that have to do with your question?
2004 Excursion 4x4
08-18-2008, 01:48 PM
1977 31' Sovereign
Manchester
, New Hampshire
sorry me dumb it is this file..
Here is correct file sorry..
K/N Cool intake air
Duel power exhaust
08-18-2008, 02:05 PM
1967 26' Overlander
Huntsville
, Alabama
A researched WAG
The schematic might be referring to power for the tongue jack.
My clue comes from this post.
Tom
08-18-2008, 03:00 PM
Princeton
, New Jersey
Not sure what problem you are chasing down but the M terminal goes to the trailer battery. The S terminal feeds the jack with current flowing from the battery to the jack. The T terminal is the feed from the TV to the trailer battery with current flowing to the battery from the TV while driving.
It is strange that the fuse at M is 50 amp when the fuse to the jack is only 30 amp. The engineer at Airstream never took DC electric 101.
What problem are you troubled by?
2004 Excursion 4x4
08-18-2008, 03:05 PM
1967 26' Overlander
Huntsville
, Alabama
Authoritative tone is great, but
Originally Posted by HowieE
... The S terminal feeds the jack with current flowing from the battery to the jack. ...
What is the basis for your statement?
Tom
08-18-2008, 03:32 PM
Princeton
, New Jersey
Without actually tracing each wire I have to go by the schematic. M is battery positive which would be necessary to feed the "Hoist" jack and is generally a 20 amp fuse. T would be the charge line coming from the TV to the positive terminal of the battery and is generally a 30 amp line.
The oddity of the fact that they use a 50 amp fuse in line with the other 2 fuses when the possible current flowing in either direction through that fuse can not exceed 30 amps. This would be if the trailer batteries were dead and you were running the trailer completely off the TV. If that load exceeded 30 amps, which is highly unlikely, the 30 amp fuse would blow first.
2004 Excursion 4x4
08-18-2008, 04:56 PM
1977 31' Sovereign
Manchester
, New Hampshire
Ok I beleive it is the "hoist" jack and it is 20 amp fuse so that should be for the electric jack... I am not thinking I was thinking it was Host not hoist da...
K/N Cool intake air
Duel power exhaust
08-18-2008, 05:25 PM
Princeton
, New Jersey
Have you solved your original problem?
2004 Excursion 4x4
08-18-2008, 06:24 PM
1977 31' Sovereign
Manchester
, New Hampshire
Yes and thank you all
look ed at it again it say's hoist not host my mistake hoist jack which makes sence thanks all.
K/N Cool intake air
Duel power exhaust
08-18-2008, 07:25 PM
1978 31' Excella 500
Venice
If you find one marked "hoist by your own petard", pull the fuse!
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Low voltage distribution panel...Help
k9s2go |
Electrical - Systems, Generators, Batteries & Solar |
4 |
12-29-2006 01:54 PM |
Low-Voltage Battery Alarm
rseagle |
14 |
04-19-2006 08:19 PM |
Low voltage-A/C
Dave-O |
10 |
04-24-2003 07:56 PM |
Low Voltage Problem
kellyw |
3 |
10-23-2002 06:35 PM |
