Old 11-19-2013, 09:38 PM   #1
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Simple & Inexpensive Battery Level Monitor?
I have searched on battery monitors and found the Trimetric and another more expensive one. But I haven't found a cheap and simple solution. I don't need a mission control level setup, I just want to be able to monitor the charge level of my two deep cycle 12V batteries during my upcoming 4-month trek. I plan to try and go 3-4 days dry camping from time to time and would like to monitor consumption.
Any inexpensive solutions that an electricity dummy like me can DIY?
Poppy
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 11-19-2013, 09:40 PM   #2
SteveH's Avatar
Common Sense , Texas
I use and like this one: INNOVA 3721 Battery and Charging System Monitor : Amazon.com : Automotive
Regards,
Steve
Old 11-19-2013, 09:52 PM   #3
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Thanks Steve. How would you wire that? (Did I mention that I'm an electricity dummy?)
Poppy
John & Vicki
WBCCI #4291
Old 11-19-2013, 10:56 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Originally Posted by Birdmaestro View Post
Thanks Steve. How would you wire that? (Did I mention that I'm an electricity dummy?) Poppy
Plug it into a 12volt outlet in the trailer. If the 12volt circuits are ok, you will get a really close reading.
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-19-2013, 11:14 PM   #5
crabbey1's Avatar
1976 Argosy 22
Pasadena , California
Images: 33
Send a message via AIM to crabbey1 Send a message via Skype™ to crabbey1
I am gonna give a vote toward the trimetric monitor. I know you want cheaper but it is an easy install and is super accurate. My favorite feature is being able to see how much amperage you are currently drawing. That way you can see exactly what certain devices take to power them...
crabbey1 is offline   Reply With Quote
Old 11-19-2013, 11:20 PM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by SteveH View Post
Hi, I have this same exact battery monitor in my trailer; It's plugged into the 12 volt socket in my bedroom.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 11-20-2013, 05:39 AM   #7
SteveH's Avatar
Poppy
Yea, you just plug it into the cigarette lighter socket, and it will give you a digital readout of the battery voltage, as well as a green, yellow, and red status lights so you can see the battery condition at a glance.
Basically, you don't want to take your battery voltage below 12.0 volts.
Have you considered a solar panel? They work great in good sunny weather.
Regards,
Steve
Old 11-20-2013, 05:47 AM   #8
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Thumbs up
Yep....KISS works for us, also plugs into the 12v power port.
PFC
but Im the Husband, so we went to Cleveland.
RLC
Step aside Starbucks, this is a job for alcohol.
Old 11-20-2013, 05:54 AM   #9
lewster's Avatar
Naples, FL , Hood River, OR
Basically, you don't want to draw your batteries down below 12.2 VDC (the generally accepted 50% depth of discharge, measured at 77F). While you can draw below this level, it will negatively effect the number of charge cycles, and thus the overall life, of your battery bank.
The Innova device will give you an estimate of your true battery voltage, but that measurement is really at the point of contact. You are, in effect, measuring the state of your 12VDC system at the 12VDC socket.
Due to the way Airstream connects the batteries to the power bus and distribution system, there will be a noticeable voltage drop from the battery terminals to the 12VDC socket, so the numbers on the gauge are simply an estimate.
If you also measure the true battery voltage at the battery with a multi-meter, you can compare that to the digital readout and get a pretty good idea of your voltage drop to that outlet and compensate accordingly.
Cheap is cheap. Nothing beats a shunt-based measuring system like the TriMetric, Magnum ME-BMK or the Blue Sky solar controllers with the IPN remote for complete and accurate battery monitoring and voltage measurement.
Old 11-20-2013, 10:36 AM   #10
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Thanks for the input. Solar panels are planned in the near future. In the meantime I'm going with one of the cheap devices. I just bought this one from Amazon - DROK Cigarette Lighter Digital Blue LED Voltage Monitor 12 V 24V+USB Car Charger 5V/2A For IPhone/IPad/IPod - Amazon.com - that displays voltage and also has a port for charging my iPhone or iPad. I like the idea of checking the voltage directly at the battery from time to time and comparing the two.
Poppy
John & Vicki
WBCCI #4291
Old 11-20-2013, 10:57 AM   #11
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
I agree 110% with lewster. In addition to the voltage drop issue he mentions, there is this; SOC tables are based on open circuit voltage. So ideally you would read the voltage with EVERYTHING disconnected from the battery which is difficult to do. Further, for the voltage reading to be a meaningful indicator of SOC, you have to let the batteries sit for an hour or so after any charging activity to allow time for the surface charge to dissipate. A device that gives you a digital reading of the voltage at a 12v outlet is better than nothing I suppose but only barely. IMHO
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 11-20-2013, 11:08 AM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Thanks for the input. Solar panels are planned in the near future. In the meantime I'm going with one of the cheap devices. I just bought this one from Amazon - DROK Cigarette Lighter Digital Blue LED Voltage Monitor 12 V 24V+USB Car Charger 5V/2A For IPhone/IPad/IPod - Amazon.com - that displays voltage and also has a port for charging my iPhone or iPad. I like the idea of checking the voltage directly at the battery from time to time and comparing the two. Poppy
Poppy,
If power at outlet is low then you can check at battery. The voltage won't be greater at outlet.
Channing
WBCCI# 30676
Old 11-20-2013, 11:16 AM   #13
2003 25' Safari
Riverside , California
Most of my camping is boondocking,even with a 50 watt solar system my wife could kill the batteries in 2 days.Now at 200 watts we get by pretty good.I don't see getting 4 days out of batteries unless you are very frugal with power useage
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
2015 Toyota Tacoma trd 4x4
2000 Jeep Wrangler 4x4
Bob4x4 is offline   Reply With Quote
Old 11-20-2013, 11:24 AM   #14
Thumbs up
Poppy
Poppy,
We tink alike...
I just bought two of these.
One to keep track of the 6v in the Ford. (mounted in a box w/on/off switch)
The other will get put in the glove box of the boat.
POI...these are within .1-.2v on my Fluke VO. I would think yours would be comparable. Take a reading at the batt's for a baseline to compare with the power port.
ID:	200364   Click image for larger version
PFC
RLC
