Old 11-20-2013, 02:50 PM   #15
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, there is the possibility that my battery monitor won't read exactly the same as my Fluke meter. Without a load on the system, I don't believe that there would, could, should, or will be any difference in the 12 volt reading at the battery or any other place on my trailer. To be actually different there has to be a load, short, poor hot, or poor ground connection. Your 12 Volt battery/ies aren't trying to start an engine. There is no major load on your 12 Volt system in your trailer.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 11-20-2013, 03:30 PM   #16
helmsman's Avatar
1967 22' Safari
Long Beach , California
Hi Birdmaestro:
The cigarette lighter voltage meter method mentioned here is easy, cheap and works great.
(A little off topic, but I believe it relates). Years ago I temporarily put an amp hour meter between the battery and the 12 volt fuse box. I turned on one 12 volt item at a time and wrote down how much each item was drawing from the battery. I posted the list inside a cabinet and used it to estimate how much was being taken from the battery. Not perfect, but it works for me. -- Enjoy!
helmsman is offline   Reply With Quote
Old 11-20-2013, 03:46 PM   #17
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up meter not load...
The difference for me is in the $39.00 Volt-Minder & $11.00 Druk.
I just note that both cheep meters are consistently low.
“We were young and knew nothing...now we're old and everyone else knows everything.”
RLC
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
"Tahawus"
