Old 04-29-2015, 07:37 AM   #1
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Silly question about converters
54 FC is currently 110 volt only so I plan to add a 12 volt system at some point. Probably four circuits: lights, water heater controls, fridge controls, and water pump. None of these loads is very high (water pump will only be intermittent and lights will be LED). No plans to install an inverter as I will not have any 110 volt only appliances except A/C which will only be used on shore power. I will install a single 100Ah AGM battery.
My question is do I really need a converter or can I use a simple four stage battery charger? If I understand correctly, a converter powers all 12 volt loads while plugged into shore power while also charging the battery as needed. A battery charger, on the other hand, would charge the battery as needed but loads would run "through" the battery which I suppose could shorten battery life?
BambiTex is offline   Reply With Quote
Old 04-29-2015, 07:58 AM   #2
Merkel , Texas
I am no expert but I believe you could do just with the battery charger and no converter. But I am not sure why you would want to. On a trip to Alaska a couple of years ago my converter ceased to work about half way through the trip. For the remainder of the trip I would hook the charger to the battery each time we had 120v service and otherwise we lived off the batteries. The inconvenience of it was what I disliked the most. It rained a lot and was just an added chore when setting up for the night. If you are going to permanently attach the charger, why not go with a converter which will be ready to use when you plug in to 120v? Plus it could provide circuit protection for the 12v circuits.
afneill is offline   Reply With Quote
Old 04-29-2015, 08:31 AM   #3
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
I intend to hard wire either device. Battery charger is smaller, lighter, less expensive and can be configured specifically for AGM batteries.
Old 11-24-2015, 12:58 PM   #4
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Finally close to moving forward on this. Any reason not to get a good 4 stage AGM charger and hard wire it to the battery instead of a big heavy converter?
Old 11-24-2015, 03:47 PM   #5
SteveH's Avatar
Common Sense , Texas
A converter is a simple power supply with the design voltage somewhere close to the output of a car's alternator, 14VDC +,-. The only thing a battery charger won't do that a converter will do, and then only if it is a smart enough battery charger, is power the system without a battery in place.
So, short answer, a battery charger will work just fine for your needs.
Regards,
Steve
Old 11-24-2015, 03:57 PM   #6
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Yes it will work. BUT, WHY? Do it right and prepare for future use and capabilities. You can get an excellent PD Converter with charging for a hundred bucks, plus or minus.
Old 11-24-2015, 04:15 PM   #7
lewster's Avatar
Naples, FL , Hood River, OR
Nothing wrong with using a quality multi stage charging system directly to the battery and then drawing the 12VDC loads from that battery. This is exactly how the expensive Magnum inverter/chargers operate when in charge mode.
Just be sure that you get one with adjustable charging parameters for different types of batteries AND temperature compensation. Your AGM battery will definitely thank you for it.
Old 11-30-2015, 08:18 AM   #8
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Recommendations?
Are there particular ones you recommend?
Old 11-30-2015, 11:48 AM   #9
lewster's Avatar
For folks not wanting to go for a Magnum inverter/charger, Progressive Dynamics makes excellent 3-stage chargers for regular use.
Even though they are not as adjustable as a Magnum and don't have temp. compensation, they still do a good job of keeping batteries well charged.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 11-30-2015, 12:04 PM   #10
Tincampers's Avatar
Sneedville , Tennessee
Lew Farber
541-490-6357
Are the PD converters adjustable at all?
Tincampers is offline   Reply With Quote
Old 11-30-2015, 12:25 PM   #11
lewster's Avatar
Not to my knowledge. They do follow a 3-stage charging profile with acceptable but not ideal voltage set points for Lifeline AGM batteries though.
Lew Farber
541-490-6357
Silly Question kamadeca General Interior Topics 3 01-28-2014 07:23 AM
Ask a silly question... thewolffman On The Road... 5 12-30-2013 12:30 AM
Gaucho? Silly newbie question egad Airstream History 4 05-18-2012 07:25 PM
quick silly question! EoinmcCabe Buyer Guidelines 5 02-05-2010 07:17 AM
silly ball height question. AV8 Hitches, Couplers & Balls 7 11-09-2003 05:32 PM
