Old 03-07-2010, 07:59 AM   #15
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question 6v negative...
Is it not true?...one 6v dies and 'yer out'a luck!!
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 03-07-2010, 08:16 AM   #16
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Pretty much. But if you only have one 12 volt battery, and a cell croaks, it also sucks to be you...
Old 03-07-2010, 08:25 AM   #17
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Costco sells deep cycle batteries for much less than RV or battery stores. The golf cart batteries I bought there were only $70. They are made by Johnson Controls.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 03-07-2010, 08:47 AM   #18
Yes...but don't you need two 6v to make one 12v?
it would suck for you to be me.
PFC
"Tahawus"
RLC
John Prine
Old 03-07-2010, 08:57 AM   #19
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
We have had the best luck with Auto Zone Duralast 12V marine duel purpose battery.
They have lasted us boondocking hard the best and are $$$ less than Optima.
Jimmini :
AKA : TUMBLEWEED. Just an old buzzard with a itch to yonder.
Cowboys have a way of looking at things a little differently than most folks.Their wisdom is simple and more down to earth.
jimmini is offline   Reply With Quote
Old 03-07-2010, 09:06 AM   #20
heslinhotel's Avatar
1989 29' Excella
1974 Argosy 26
1999 25' Safari
Youngsville , North Carolina
Had a 79 31' with 2 battery compartments with deep cycle Interstate batteries. To add extra capacity I installed 2 6v golf cart batteries in a battery box mounted between frame rails just behind propane tanks. Battery box was mounted on 2 pieces if 1" angle aluminum bolted to bottom of frame. You have to move propane tank mount 1" forward and re-weld to frame to fit. Should give you all the power you need for a weekend of boondocking. I bought battery box online from a supplier in Washington state. Ran 8ga wire from 6v thru vent for univolt to fuse panel. Worked well for me.
heslinhotel is offline   Reply With Quote
Old 03-07-2010, 09:12 AM   #21
Batteries are made up of a series of 2 volt cells.
A 6 volt battery has 3 and a 12 volt has 6 cells. There is nothing that can be done to alter that.
However, when you put batteries or lights as an example, in series, when one fails, they all fail, just like the old Christmas tree lights.
As an example, take 2 100 amp 6 volt batteries, 600 watts each and put them in series. You will have 12 volts at 100 amps, or 1200 watts.
Then take 2, 50 amp 12 volt batteries and put them in parallel. You will now have 12 volts at 100 amps, or 1200 watts.
The big draw back with the two 6 volt batteries in series is when one quits, your done. When batteries are in parallel, when one quits, you remove it, and you still have a source of power.
"IF" 2 six volt batteries was a better deal than two 12 volt batteries, Airstream would have switched to that many years ago.
The odds of power failure with 2 six volt batteries in series, is "TWICE" that of 12 volt batteries in parallel.
Twelve volt batteries are easily found, not so any more with 6 volt batteries.
Go to Costco, and see how many of each they have on display.
Lastly, more than likely a battery will fail when on a trip. With the 6 volts, your done, no matter what you do. Now your trip has a problem, because you will have to search for 2 batteries.
With the 12 volts, remove the bad one, and replace it when you get around to it, perhaps not until you get back home.
The only test equipment needed for the 12 volt battery setup, is a cheap volt meter.
Old 03-07-2010, 09:15 AM   #22
1989 29' Excella
1974 Argosy 26
1999 25' Safari
I purchase my batteries from an Interstate wholesale supply house locally. I usually get "blems" that have a scare on outter case, but batteries are new with warranty. Cost on the 2 12v were $30 each, 6v were $40 each. Beats the retail prices and allows you to repalce as necessary without breaking the bank.
Old 03-07-2010, 09:25 AM   #23
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Why would you only have one 12 volt?
If you have room for two 6 volts. you've got room for two 12 volts.
Old 03-07-2010, 09:29 AM   #24
1989 29' Excella
1974 Argosy 26
1999 25' Safari
On my current 31, it had only a single battery. The external box hatch was intact but inner plastic box was missing. I bought 2 covers with plastic boxes from a wrecked 06 Classic. Had to modify the box to hatch connection due to angle of cover, but now have an enclosed battery box to contain battery gases from entering the cabin. The support wire on cover was too short to allow the hatch to open a full 90 degrees. this made fitting type 78 deep cycle from fitting. I had to lengthen it. The support wire was not really necessary because hatch will be stopped by frame a little over 90 degrees anyway. I am still contemplating wether I am going to put in the additional 2 pack of 6v batteries on this one.
Old 03-07-2010, 09:34 AM   #25
Ag&Au's Avatar
Do your batts have handles?
This is not the brand or style battery I use...(best picture though). I struggled with the same problem til I fastened a pull strap attached to the end of the battery where the handle is attached.
Lift up and slide out, it still ain't easy with a heavy AGM but it is doable..
Good idea. I am going to look into that. I use a strap horizontally around the battery, but your method looks like it would work better. I also have a thin piece of slick plastic to help the battery get up over the lip of the compartment.
Regards,
Ken
Old 03-07-2010, 09:50 AM   #26
Ag&Au's Avatar
Battery testing.
First of all, let me establish my credentials - I am not a battery expert and make no claim to be.
The only reliable way, that I am aware of, to test a battery's condition (not just whether it is charged or not) is to fully charge it and hook it up to a known value load. Then plot the voltage over time as it discharges. Compare that to the specifications. I have a device that does that. It connects to a laptop computer and plots a chart of the battery's performance. I have only used it a few times. What I learned is, that by the time I think it is worth doing, I pretty much know the battery needs to be replaced anyway.
Regards,
Ken
Old 03-07-2010, 09:51 AM   #27
Regards,
Ken
Yeah...that little 1/4" lip is a real PITA......I'll find that piece of plastic and give it a try, that with the lift strap==piece of cake.
Thanks....Bob
PFC
"Tahawus"
RLC
John Prine
Old 03-07-2010, 01:38 PM   #28
2011 28' Flying Cloud
chanhassen , Minnesota
Is the "Point" of a battery blade to disconnect it when connected to A/C?
kentuvman is offline   Reply With Quote
tired tires Pop Rivet Classic Motorhomes 6 09-03-2006 09:00 PM
Tired 1975 Trade Wind rwnash Member Introductions 3 05-26-2006 05:38 AM
MY Sick 310 JMChrystie Our Community 3 03-07-2004 02:53 PM
I must be sick ? Bfrank Airstream Motorhome Forums 14 08-14-2002 02:30 PM
