Old 10-24-2017, 06:25 PM   #21
2010 20' Flying Cloud
Clearwater , British Columbia
Originally Posted by pteck View Post
I would say no to the upgrade. In my situation, there wouldn't be any value for the money spent.
For incrementally more money than an upgraded converter, I was able to install solar, which has its own 4-stage charge controller with temperature compensation. I park outside. So it alone is what manages the day to day charging and maintenance of the batts.
Therefore the original converter is only utilized when I go camping in a full hookup sites. In these situations, I use the trailer in the store position, which decouples the converter from the batts.
So the original converter-charger is largely used for its converter function and rarely as a battery charger anymore. Perhaps the only use case as a charger would now be boon docking in extended overcast conditions where I may use it with a generator.
Thanks! I've ordered the OEM replacement 55RU. I am happy with the solar package, but there are a lot of additional draws on the 12V, especially the fans, not to mention the various tank heat pads, that for several months of the year the converter will be needed with either shore power or the generator hooked up.
BCMtnHound is offline   Reply With Quote
Old 10-24-2017, 10:16 PM   #22
New Borockton , Alabama
Images: 21
Before you "hijacked" these folks were helping the OP with better options you could have even got in Canada locally maybe. You are not going to like that 55RU unless you don't run a battery or voltage doesn't matter. It will charge your battery single stage though if that is what you need.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
12V converter/battery/monitor upgrade dznf0g Batteries, Univolts, Converters & Inverters 35 01-31-2016 07:49 PM
Deal(er) or no deal(er)? Where should I get repair / upgrade done? longdog General Repair Forum 11 09-18-2013 08:05 PM
Should I upgrade?? politicurl Towing, Tow Vehicles & Hitches 4 10-23-2012 05:49 PM
Converter Upgrade nickmeloy Batteries, Univolts, Converters & Inverters 2 10-11-2010 03:50 PM
Upgrade converter in '05 Classic 31? bandboss Batteries, Univolts, Converters & Inverters 3 03-01-2006 05:58 AM
