Old 07-21-2019, 12:11 PM   #1
2019 23' International
Portland , Oregon
Should I make longer cables so I can actually check the battery level?
You'd think they didn't think of it. Click image for larger version
2019 International Signature 23FB "Cecil"
2005 Yukon XL
Former coach: 2015 Bambi 16 "Beanie"
leedav is offline   Reply With Quote
Old 07-21-2019, 12:17 PM   #2
2007 22' International CCD
I would. Thatís not at all convenient.
Amazon sells premade battery cable assemblies with marine grade cable and lugs with adhesive shrink tubing already installed. They make them in various lengths and wire sizes.
Happy customer...
Old 07-21-2019, 12:41 PM   #3
Portland , Oregon
Happy customer...
2005 Yukon XL
Old 07-21-2019, 02:18 PM   #4
Mattirs's Avatar
2016 25' Flying Cloud
Fairfield , California
I just rotated my batteries so the caps face outwards and is so much easier to check the water levels.Click image for larger version
ID:	347260Click image for larger version
Mattirs is offline   Reply With Quote
Old 07-21-2019, 02:18 PM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Probably cheaper to replace the cables than convert the batteries to AGM's so you don't have to check them
Old 07-21-2019, 02:25 PM   #6
Portland , Oregon
I'll try that first. Not sure if there are trays at the bottom
Originally Posted by Mattirs View Post
I just rotated my batteries so the caps face outwards and is so much easier to check the water levels.Attachment 347260Attachment 347261
2005 Yukon XL
Old 07-21-2019, 02:27 PM   #7
Portland , Oregon
Although I don't love the proximity of the + & -
2005 Yukon XL
Old 07-21-2019, 02:33 PM   #8
waninae39's Avatar
2017 22' Sport
NCR , Ontario
our victron system give us remove access to the battery , solar and Ac status
Name:	victron monitor status.JPG
waninae39 is online now   Reply With Quote
Old 07-21-2019, 03:03 PM   #9
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Any AS trailer that is stored should have a battery disconnect switch. The wiring for a switch requires modification of existing cables. If you think you want to improve access to the batteries for better electrolyte checking and filling, any mods should include the addition of a disconnect switch.
Now, if your batteries are near end of life, the upgrade of the bank would have value. AGM, more wet cell capacity, 12V to 6V transition, or the ultimate move to lithium .... so don't just look at a set of battery cables. Look at what upgrade would make your coach most valuable to your RVC use.
Nails in the nails soup is a parallel consideration. Pat
Old 07-21-2019, 03:51 PM   #10
Portland , Oregon
Why do I need a disconnect switch? I just undo the negative cable when I store
2005 Yukon XL
Old 07-21-2019, 03:56 PM   #11
Mattirs's Avatar
There is a tray underneath the batteries, but all you are doing is rotating one battery 180 degees, it sits right back down in the same place.
Matti
Old 07-21-2019, 04:45 PM   #12
Portland , Oregon
Doh!
Matti
2005 Yukon XL
Old 07-21-2019, 05:04 PM   #13
2019 Interstate Lounge Ext
Grand Ledge , Michigan
2019 Airstream Interstate
Where is the coach or house battery located. The manual does not show it. We bought the vehicle 3 weeks ago and the battery is dead inside the coach. Battery is still working for the vehicle. Help
DopplerDave is offline   Reply With Quote
Old 07-21-2019, 05:11 PM   #14
2019 30' Flying Cloud
Grass Lake , Michigan
My new AS looked identical from the factory. I complained at delivery and the dealer made longer cables so I could check water levels. Unfortunately, they overfilled the batteries and spilled acid inside the box and it rusted. Sheís at JC now for several warranty issues and they are repainting the battery box.
oldenavy is offline   Reply With Quote
how do you make post preview last longer? trucker101 Forum Admin, News and Member Account Info 6 04-19-2009 05:43 PM
Longer Battery Cables - Replace or Splice? RDM16CCD Batteries, Univolts, Converters & Inverters 3 02-26-2007 10:01 PM
Don't forget: Check your battery water level.... Safari Tim Batteries, Univolts, Converters & Inverters 2 11-14-2004 12:30 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
