Old 06-08-2016, 08:47 PM   #1
1975 27' Overlander
Miami , Florida
Should I change the univolt?!
Hi fellows Airstreamers, first thanks for all the knowledge you have shared, has been a great help for us restoring our 75 overlander. We have a electrical problem, first my battery is dead I am planing to get a new one, also the power jack only does work when the trailer is plug to shore power. As far as I know the univolt is working but I think it fried my old battery. should I upgrade the whole system or just buy a new battery for the time being?
Thanks and safe travels!!
Francisco is offline   Reply With Quote
Old 06-08-2016, 09:19 PM   #2
Southwestern , Ohio
Welcome to the forums!
"As far as I know the univolt is working", but the old battery is dead and you think it fried it! As a philosophical comment, if the univolt isn't keeping the battery charged when plugged into shore power, it isn't working. And if it fried the old battery, it isn't working very well!
You can tell pretty quickly whether the univolt is working just by measuring the voltage at the battery terminals with shore power connected and disconnected. A fully charged battery will show between 12 and 13 volts with shore power disconnected and 13-14 volts with shore power connected.
In any case, modern multi-stage converters don't cost much, take ever so much better care of your battery than the old iron ones, and weigh 50 to 100 pounds less. As far as I am concerned, change out the old one when you replace your battery. The old one will make a good boat anchor.
Nuvite-F is offline   Reply With Quote
Old 06-08-2016, 09:54 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Dump the Univolt: Buy a multistage converter like a Progressive Dynamics 9245. Unless you are traveling you won't need to buy a battery. Just tape off the battery cables so they don't short out.
IMHO you should also upgrade to the modern blade type fuses.
You can to the entire converter/fuse upgrade for less than $200.00
Old 06-09-2016, 06:14 AM   #4
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
What Twinkie said times 2. VERY inexpensive as things go in Airstreams. I would put in a battery once your renovations are nearing completion. Even if you don't plan to travel much, there's always the "hurricane bug out" or the kid has measles (and he was vaccinated!) isolation ward. Having a battery keeps the CO sensors, etc. working during power outages.
Paula
Old 06-09-2016, 12:46 PM   #5
GR8DANE's Avatar
1966 22' Safari
1964 24' Tradewind
1956 18' "Footer"
Southern , Minnesota
Upgrade now or keep buying new batteries. Univolts kill batteries. Old, inferior technology.
life is too short to drink cheap beer...unless that's all we've got and then pass me a cold one!
Steve "Dancin" Hansen
TAC MN-31
visit my almost yearly blog http://www.bluessafari.blogspot.com
GR8DANE is offline   Reply With Quote
Old 06-09-2016, 07:09 PM   #6
1975 27' Overlander
Miami , Florida
Thank you guys, for the replies, I'm going to and replace the whole system and get a new batterie. Better safe than sorry!!
Safe travels!!
Change out of Univolt stephenh2 Batteries, Univolts, Converters & Inverters 22 02-06-2012 03:34 PM
Change Univolt If It's Working ???? Clyde-2 Batteries, Univolts, Converters & Inverters 23 09-30-2009 07:54 AM
change to a univolt from a convertor rye Batteries, Univolts, Converters & Inverters 2 09-10-2009 09:14 AM
Change-out Univolt for WFCO Bulldogger Batteries, Univolts, Converters & Inverters 10 11-09-2007 08:11 PM
Should I change my oil? Turtle Mechanics Corner - Engines, Transmission & More... 18 07-07-2004 12:18 PM
