Old 11-17-2016, 08:15 PM   #1
2018 26' Flying Cloud
Shore power not charging battery after battery replacement
I replaced the battery in my 2008 Safari Sport 22. Shore power no longer seems to charge. Suggestions on diagnosis or repairs?
P and Y is offline   Reply With Quote
Old 11-17-2016, 08:39 PM   #2
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
So what else is or is not working?
Will a long tow charge the battery?
Is everything electrically working when shore power is plugged in and running?
Are there any loose connections on the battery cables to the battery?
Did the previous battery hold a charge/work less and less well, or quit suddenly?
Does you model airstream provide you battery charge levels on your monitor? If so what are the readings?
Battery switch (use/store) is set correctly?
Any smells coming from the battery area?
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 11-17-2016, 09:27 PM   #3
Everything else seems to be working.
Battery switch is set to on.
Old battery was over 4 years old and was not stressed much. It was low in water and not holding a charge and we had a trip, so I replaced it. No smells.
Old 11-17-2016, 09:28 PM   #4
I think the tow vehicle is charging it.
No lose connections.
Old 11-17-2016, 09:31 PM   #5
Battery charge indicator showed low, and lights were dim which made me aware of problem even though on shore power for days.
I put an external charger on battery and it is fully charged.
Old 11-17-2016, 09:32 PM   #6
New Borockton , Alabama
Images: 21
See if your converter is supplying voltage. Could have blown a fuse near the battery bank while changing the batteries or could be converter. You should have at least 13.6 on the DC fuse board and it needs to make it to your batteries or will not charge. Might be something simple but hopefully you aren't using the stock Parallax converter if you bought new batteries.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 11-18-2016, 08:24 AM   #7
Thanks. Is the converter behind the fuse panel? Sorry for the stupid question.
Old 11-18-2016, 08:33 AM   #8
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
It is below it
Larry
lsbrodsky is offline   Reply With Quote
Old 11-18-2016, 12:49 PM   #9
Thanks. Found it. I'll test it when I get shore power.
Old 11-18-2016, 01:39 PM   #10
honi soit qui mal y pense
Robere's Avatar
2015 23' FB Flying Cloud
Bend , Oregon
Recommend a multistage converter if you haven't already replaced the original.
Robere (aka Pepe) & Jacqueline (aka Gigi)
with pups Ella (the miniature poodle)
and Tibet (the Lhasa Apso)
2016 Chev Silverado LT Crew 4x4
Robere is offline   Reply With Quote
Old 11-18-2016, 02:24 PM   #11
1977 31' Sovereign
2005 30' Safari
1977 28' Argosy 28
North Port , Florida
Sounds like it might be a bad disconnect relay or switch. If it's stuck in the store/disconnect position then the batteries are disconnected from the converter. I'd put a charger on the battery, unhook from shore power and see if your 12v works.
cliffcharb is offline   Reply With Quote
Old 11-19-2016, 08:56 AM   #12
The lights run when disconnected from shore power. I did put a battery charger on the battery to bring it back to life. We did accidentally hit the disconnect switch and the lights actually flashed on and off until I put it back on the "on" position. That seemed strange. Does that indicate something?
Old 11-19-2016, 08:59 AM   #13
My Airstream is a 22 foot Safari Sport 2008 with only 1 battery. What multistage converter would be best?
Old 11-19-2016, 09:17 AM   #14
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
when I needed a converter this is who I asked:
http://www.bestconverter.com/Ask-Randy_ep_18-1.html
I have purchased two converters from Best Converter.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 11-21-2016, 08:15 AM   #15
la nomade's Avatar
2018 22' Sport
stanfordville , New York
i found you here!!!!a good thing....great suggestions and advice,it will solve your problem..M
la nomade is offline   Reply With Quote
Old 11-22-2016, 09:36 AM   #16
Tested the converter and it seems dead, so ordered a new Progressive Dynamics from Randy based on his suggestion and my research. Will keep you posted.
Batteries charging from solar but not shore power johndorst Batteries, Univolts, Converters & Inverters 3 11-16-2016 04:18 PM
Batteries not charging via shore power??? crazylev Electrical - Systems, Generators, Batteries & Solar 29 08-30-2016 09:35 AM
Battery charging when connected to shore power. Wingeezer Batteries, Univolts, Converters & Inverters 3 07-15-2011 11:12 AM
Charging battery on shore power. Dr Dan Batteries, Univolts, Converters & Inverters 8 08-26-2010 03:07 PM
Charging Battery While Plugged in to Shore Power Kevin245 Batteries, Univolts, Converters & Inverters 2 12-29-2007 02:10 PM
