Old 10-09-2013, 09:43 PM   #15
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The answer is in this symbol: $$$
I retrofitted a three stage charger in my 2013 25FB International factory box as soon as I read about it here in the forums and have had no burned up batteries this year.
Old 10-10-2013, 04:28 AM   #16
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Originally Posted by idroba View Post
I am guessing here, but the power center that the Paralax converter/charger is in appears to be a standard RV type, complete with both the 120 volt circuit breakers as well as the 12 volt side, including the converter and fuses. Apparently Paralax is the only one who makes such a combination, and it is convenient for the RV manufactures to use it rather than supping an individual 120 volt circuit breaker panel, a converter/charger, and a 12 volt fuse panel. The RV manufacturer deals with, and wires, one device, rather than three.
Paralax does not make a unit, as far as I can find, with a 3 stage converter/charger section, so if AS wants to use the single box system with all 120 and 12 volt parts in one unit, they cannot buy it with the 3 stage converter/charger, and no one else makes one which has all three parts either.
Now Progressive Dynamics makes a converter/charger with 12 volt fuse panel which fits directly into the Paralax box, but they do not make a rival total 3 part box that a manufacturer can purchase. So, for AS to use the single box 120 volt circuit breakers, converter charger and 12 volt fuse system, they are forced to use Paralax equipment. I can remove the guts of the converter/charger and fuses but they cannot, and have anything which is cost effective for them.
I am speculating of course, but bet I am close to the real reason that AS continues to use the Paralax single stage converter/charger.
Well it's not the retail price that keeps AS from using a "good" unit.
There is a difference in price......but.
.....both are stand alone with separate distribution panels.
IOTA DLS 55a IQ4
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
