I need more battery power. The Standard battery location on my Argosy limits me to a Grp. 24 or maybe Grp 27 battery, so I think my answer is a pair of AGM batts under the bunk, behind the bulkhead in my Argosy 24.I know... one is not supposed to use batts indoors, given that, here is what I would like to do...
1. Retain the existing Univolt converter for 110 use.
2. Add two 100+ AH Deka AGMs in hold downs under the road side twin bed and,
3. Install a Guest marine three stage 10 Amp two bank charger hooked to the city power input.
4. Run the output from the AGM batts to the
12V main distribution.
I do NOT want to use the Univolt to maintain charge on the AGMs I do not think it will do the job correctly.
NOTE: I would like to use the
12V TV feed to maintain the AGM batteries when driving.
I have studied the wiring diagrams, but am not clear on whether can be done, and whether I will have problems... I am leaving for Montana in one month, and want to get this done, installed and working by then.
Can anyone offer their experience to assist?
