Old 12-08-2018, 12:55 AM   #1
2016 30' International
redondo beach , California
Screwing Converter to Airstream Wall.
Looking for some input here.
In the front of our trailer, under the storage box/couch/slide out bed thingy we have the use/store relay, a couple of bus bars, the 7 way plug terminal box, and other stuff. This is all screwed to a piece of plywood which in turn is screwed to the interior wall of the trailer.
For various reasons I would like to use sheet metal screws and mount my two converters on the wall on either side of this assembly.
What do you think of mounting these devices to the interior aluminum wall with sheet metal screws?
Thanks.
Randy and Beth
2015 F250 Titan 50 gallon
2016 30' International ProPride, EasyStart, Michelin 16", 400AH LiFePO4, Victron BMV 712, Orion DC/DC converter, BlueSolar MPPT 100/30, Victron 12|1200 inverter, 300W solar mix, Alpine iLX, Polk MM1, Samsung 42, one small air plant
mythbuster88 is offline   Reply With Quote
Old 12-08-2018, 01:11 AM   #2
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
Not a problem .
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 12-08-2018, 07:28 AM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Depends, on the weight being hung and how many fasteners to resist the tearing/shear effect.
IMO, if more than a pound or two, it would be best to mount onto thick plywood that extends to the floor, with plywood fastened to the wall, so that the weight is carried by the floor instead of thin aluminum.
Each time the trailer bounces the weight of an object mounted on the wall is multiplied. The more harsh the bounce the higher the weight.
Alan
Old 12-08-2018, 08:52 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
two converters?
Richard
Old 12-08-2018, 10:30 AM   #5
Originally Posted by azflycaster View Post
two converters?
Doubles the current.
Randy and Beth
Old 12-08-2018, 10:58 AM   #6
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
sheet meta screw should work fine but I think i would use wood between for extra strength plus minimize any chance of any vibration.
Haven't heard about using 2 converters??
rucos is offline   Reply With Quote
Old 12-08-2018, 10:59 AM   #7
One side of the converters will rest on the floor.
Four fasteners.
~6 lbs.
Progressive Dynamics PD9160 ALV.
Randy and Beth
Old 12-08-2018, 11:23 AM   #8
With two converters in parallel we can double the current.
Each is rated at 60 Amps. Usually we get around 100 Amps when both are plugged in but the current really depends on the input AC voltage.
When both are working it is a significant load and too much load for a single Honda 2000 so two generators in parallel are required if we want to reduce the time needed to charge the batteries
But there are times when we only use one converter.
The whole point is to have some flexibility and reduce charging time when boondocking.
Randy and Beth
Old 12-08-2018, 11:55 AM   #9
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
no problem. I mounted several electrical components directly to the wall like that when I did my solar install. They are still solid in place after two years of any washboard road trips for boon docking
Troutboy
Troutboy is offline   Reply With Quote
Old 12-08-2018, 12:12 PM   #10
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 21
With one side on the floor, the weight issue is dealt with, so screws should be sufficient to secure in place. My only concern is over tightening the screw and stripping out the aluminum sheet and/or holding power if you remove the unit and reinstall. My experience in doing autobody is they don't always hold as well the second, or third time installed.
I would suggest an alternative: Use riv-nuts so you have a machine thread and have no issues with removal and reinstall.
Harold & Rebecca
http://www.airforums.com/forums/f97/...er-172124.html
57Vintage is offline   Reply With Quote
Old 12-08-2018, 12:23 PM   #11
1972 25' Tradewind
1976 31' Excella 500
Denver , Colorado
If you own an Airstream, you should spend the $5. ;-)
https://www.harborfreight.com/hand-r...set-38353.html
25' 1972 Airstream Trade Wind Land Yacht
2006 Jeep Liberty CRD (diesel)
http://BeahmStream.com
kidjedi is offline   Reply With Quote
Old 12-08-2018, 01:05 PM   #12
Life is a Highway's Avatar
2019 25' Flying Cloud
Lady Lake , Florida
Velcro
I am one that never likes to screw into thin aluminum if not absolutely necessary. Rivets in aluminum or a screw into the wood
One option I have used is industrial strength Velcro. Properly applied it can handle the weight and any bouncing
Just a consideration.
Life is a Highway is offline   Reply With Quote
Old 12-08-2018, 06:32 PM   #13
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Four fasteners.
~6 lbs.
Should be ok setting on the floor with minimal attachment to the wall, as long as no ventilation holes are blocked.
I'm curious. How will you interconnect the two converters. Will they sense each other's output and react properly (output voltage and/or mode)? I do not think so.
Maybe adding a converter, a small battery, and separate new outlets at work stations makes more sense. (none of this connected to the original wiring) It would be easier to restore to original if need be.
Alan
Old 12-09-2018, 11:45 PM   #14
They are in parallel.
The manufacturer fine print claims that its OK and I have been using them like this for about a year.
In fact we have the solar controller, the two converters and the DC to DC converter that are in parallel.
Randy and Beth
Screwing My Bambi? Airrogant General Repair Forum 5 04-30-2014 09:40 AM
Screwing into fiberglass bath ceiling? SummitAir Sinks, Showers & Toilets 4 10-22-2008 12:16 PM
screwing through floating laminate DasAir Floor Finishes 6 04-07-2008 08:02 PM
Screwing into walls? starflyte1 General Interior Topics 2 03-19-2007 07:33 AM
BAL jack, nut keeps un-screwing Kistler Jacks, Stabilizers, Lifting and Leveling 7 06-08-2006 11:07 PM
