Old 03-20-2015, 04:12 PM   #15
2014 27' Flying Cloud
Stowe , Vermont
Welcome Easler 7267 - Your new AS friends above have given you great information. Just a couple extra notes. 1. The 30 amp connector in the front can be used for both a generator or shore (campground) power. We used our's last summer when the campground's power supply was far in front of the site. It serves the same purpose as the 30 amp on the side of your AS. 2. If there is 50 and 30 amp offered, I have found every campground has 2 electric hookups on the electric post - one 30 - one 50. Your 30 amp power cord that was given to you with the AS will fit all 30 amp supplies. If there is a 20 amp ONLY on the electric post (no 30 or 50) you should carry an adaptor for 30 amp to 20 amp. It may even be in your AS package. Do not use your AC with 20 amp hookup.
VT Wanderer is offline   Reply With Quote
Old 03-23-2015, 12:10 PM   #16
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
If you have a 30 amp trailer, you can get a 30 amp to 50 amp adapter to plug into power and vice versa.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-05-2015, 10:53 PM   #17
johnnywood's Avatar
1978 31' Sovereign
1968 24' Tradewind
Salem , Oregon
But this part of the owners manual makes it sound like you could plug into 50 amp service using this remote generator hook up. Am I wrong about this? As I said before my wife and I are newbies at this and would appreciate any advice!
Hey easler7267, could you take a picture or a scan of that part of the owner's manual? Maybe this is something that Airstream needs to fix and update.
Just very curious.
-johnny
johnnywood is offline   Reply With Quote
Old 07-05-2017, 05:17 PM   #18
Virginia Beach , Virginia
I am a newbie also and have a 50 amp service. I wanted to know if I'm connected to a 30 amp service can I still use one of my two AC's?
petermday is offline   Reply With Quote
Old 07-05-2017, 05:36 PM   #19
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Yes, a proper connection to 30A service should run one of your ACs. A "proper connection" would be a good-quality 30A-to-50A adapter and a 30A socket in good repair.
— David
Old 07-06-2017, 04:51 AM   #20
Thanks David for the info. I probably shouldn't but I'm assuming that by a proper 30 Amp socket your talking about the campground supply line/plug.
Old 07-06-2017, 05:56 AM   #21
DKB_SATX's Avatar
1976 Argosy 28
Right, the campground socket. Just make sure it's not damaged or loose, and that the voltage isn't too low.
— David
Old 03-06-2018, 06:21 AM   #22
Overton , Texas
I have a 50A trailer. Is there any danger using a y connector, 2-30A to 50A when the electric connection at the park has 2 30A outlets? I assume the Y connector enables you to have 50A service, but I am new to this.
tmeadows14 is offline   Reply With Quote
Old 03-06-2018, 06:52 AM   #23
2018 28' International
Fayetteville , Georgia
As you have not picked up your new AS yet, check with your salesman to see if you have 30 or 50amp connections. If you have a 30 amp system, your trailer will have one a/c on the roof, and an additional connection at the front of tje trailer to connect a generator. The generator connection is only used when you are camping without ac power, and is only found on 30 amp trailers.
If your trailer has two a/c’s on the roof, you will have a 50 amp system. It takes more power to run both a/c’s , so that is why you need the higher capacity 50 amp service.
30 and 50 amp systems have different plugs. A 30 does not fit into a 50amp receptacle and vice versa. There are adapter plugs, generally used when you have a 50 amp trailer and the campsite only has a 30 amp plug. If connected to a30amp campsite, you do not have enough capacity to run both a/c’s.
Hope this helps.
brick
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 03-06-2018, 06:59 AM   #24
Overton , Texas
I understand the 30 vs 50, but have seen an adapter with 2 30 male connectors on one end with a 50 female on the other end. If the electric box has 2 30A outlets, can this adapter be used to have 50A service? Hopefully I worded it correctly this time.
Old 03-06-2018, 07:41 AM   #25
waninae39's Avatar
2017 22' Sport
ottawa , Ontario
30A service is one phase on 110V
50A service has two phases of 110V- like most homes
YEs, you can get an adapter that will use one of the two phases
look for one that has
50A male and a 30 A female ends
waninae39 is offline   Reply With Quote
Old 03-06-2018, 07:56 AM   #26
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Originally Posted by brick1 View Post
... an additional connection at the front of the trailer to connect a generator. The generator connection is only used when you are camping without ac power ...
This power input is controlled by an automatic transfer switch. I use it instead of the one on the side of the trailer if it is more convenient to the power pedestal.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 03-06-2018, 08:07 AM   #27
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
This should be your first purchase, $3 at WalMart. This device is a quick way to detect a hot neutral swap/ hot shell condition.... This will save your life!
Google Airstream hot shell and see what that means.
Old 03-06-2018, 08:38 AM   #28
I just realized the original post goes back to March of 2015. My bad. Hope the OP has his new trailer by now...��
brick
brick
Cute wife...
Replacement 50Amp Cable JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 2 04-08-2013 06:03 AM
50amp Conversion / Addition TomR Electrical - Systems, Generators, Batteries & Solar 6 11-03-2007 12:07 PM
50amp for 30amp trailer? racoco Electrical - Systems, Generators, Batteries & Solar 15 08-24-2007 07:43 PM
Power Inlet 50amp markdoane Electrical - Systems, Generators, Batteries & Solar 4 10-14-2005 08:25 PM
30amp to 50amp? alfalsetto Airstream Motorhome Forums 17 08-16-2003 06:42 AM
