Old 02-22-2009, 02:19 PM   #1
1972 31' Sovereign
Rosenberg , Texas
rv converter/charger
My converter is shot in our 72 Sovereign I am new to the community and would greatly appreciate some advice. I was thinking of buying an Inteli-Power 9200 Series. Their are some ranging from 45A to 80A what converter does someone recommend? Any help would be appreciated Thanks!
j&smarin is offline   Reply With Quote
Old 02-22-2009, 02:22 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I recently installed a 9245 (45 amp) in my 75 Trade Wind. It is large enough for all of my 12 volt needs. I only have one battery in my trailer, if I had more I would have gotten a higher rated converter.
On edit: Welcome to the forums!
Richard
Old 02-22-2009, 02:40 PM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
I use the 45 amp model 9200 in all my Airstreams and haven't blown a fuse, even on the 2-battery setups. If you want some margin, get a 60-amp. You will never need anything bigger than that.
Zep
Old 02-22-2009, 03:04 PM   #4
nd48463's Avatar
1977 31' Excella 500
Emmett , Michigan
Images: 72
I also was going to go with the Intelli-Power but found a Parallax 7400 on Ebay for $90! He had four of them and I believe that he still has some listed. It was shipped in original packaging with all original paperwork. I could not pass it up, and it should work fine. Anything is better than that buzz-box under the front gaucho!
Nate
nd48463 is offline   Reply With Quote
New Xantrex Converter/Charger 68 Overlander Commercial Listings 6 07-25-2012 07:01 PM
converter / battery charger HoosierGypsy Batteries, Univolts, Converters & Inverters 3 12-28-2008 10:56 AM
charger / converter survey Uncle Jack Batteries, Univolts, Converters & Inverters 6 05-17-2007 10:53 PM
New Converter / Charger on the block 68 Overlander Commercial Listings 19 03-07-2007 10:54 AM
Converter/battery charger ARGONUT Batteries, Univolts, Converters & Inverters 0 11-23-2003 04:28 PM
