Old 05-20-2015, 04:29 PM   #15
1964 24' Tradewind
Fallon , Nevada
Well, as I pointed out ... there's much more to the story. In my motorhome, I took out the 3 way fridge. I installed a new Norcold 110/12 volt refrigerator. It's a tad smaller, at 7 cu. ft., but 2 door and it draws about 40 watts. It utilizes a VERY well respected Danfoss variable speed compressor cooling system. I installed solar panels that will much more than power that miniscule power drain.
I just put 250 watts of panels on my Avion. I think I will sell the 3 way and install the same super-efficient Norcold in there too.
1964 Airstream International Tradewind
1985 Avion 40R
1989 Monaco Crown Royale
1991 Dodge Cummins TV
wrhjr3 is offline   Reply With Quote
Old 05-20-2015, 04:32 PM   #16
1964 24' Tradewind
Fallon , Nevada
Typo........1985 Avion 30R
Old 05-20-2015, 05:17 PM   #17
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I installed a Magnum MSH inverter in my new Classic along with four Lifeline 6V batteries. Also 600 Watts of solar. In rewiring the main panel into the sub-panel (inverter circuits), I moved the 120V fridge wiring onto the sub-panel -- which means I can run the Dometic off the inverter rather than use propane. IF I'm traveling on a sunny day, the panels will keep the batteries well above the programmed low battery cutoff point (this is programmed into the inverter and keeps you from over-draining the batteries --- which could cause them to be damaged). I tried this set-up and it does work.....but for all practical purposes, it's a LOT easier to let the Dometic flip over to the propane. Then if we pull over in a rest stop and want to have a sandwich with toast, or use the microwave there's plenty of "juice" in the batteries to use the heavy power consumers.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 05-20-2015, 05:44 PM   #18
mandolindave's Avatar
It is a great question though
Other better options.
Just run the fridge on propane while driving.
If for some reason you can't or won't. You can run the fridge on 110 for a few days before departure ( you really need to do that any way ) Then put frozen bottles of water in the fridge right before you leave, and don't open the fridge until you arrive at destination.
mandolindave is offline   Reply With Quote
Old 05-20-2015, 06:37 PM   #19
2002 22' International
Corvallis , Oregon
I installed a 10 gage wire from the TV batteries thru a fuse to an outlet on the back bumper, then I have a separate wire from a matching plug thru a 120 volt controlled relay to a 300 watt invertor powering my Dometic model 2452 120 volt refrigerator. This refrigerator uses less then 2 amps to keep it cold. 2 Amps x 120 volts is 240 watts, divide that by 12 equals 20 amps from the TV batteries.
If you have a 100 amp alternator on your TV, you should not have any issues keeping everything cold.
I have a homemade lashup that has been working just fine. Total cost including the wire about $300.00
boblind is offline   Reply With Quote
Old 05-20-2015, 10:24 PM   #20
2016 30' International
Scottsdale , Arizona
A lot of great info here, thanks folks for your comments!
DHart is offline   Reply With Quote
Old 05-21-2015, 06:16 AM   #21
2013 27' FB Classic
Crestview , Florida
I have 4 solar panels and a 2800watt inverter. On an average sunny day my solar keeps the batteries at a 100% charge even though the inverter is running the fridge and other items. I guess I did a proper installation. Running down the road with gas on is dangerous.
david1622 is offline   Reply With Quote
Old 05-21-2015, 09:37 AM   #22
Corvallis , Oregon
I use a 300 watt invertor supplying enough power to the 120vac circuit to the refrigerator. The refrigerator keeps ice cream hard enough to stop for a cone traveling through Nevada.
I use separate dedicated 12vdc 10 gage wires from the TV to the invertor not the regular7 prong 12 vdc supplying power to the AS for brakes, lights, and trailer batteries.having propane on while traveling is just asking for problems.
Old 05-21-2015, 12:59 PM   #23
2007 27' Safari FB SE
Cambridge , Wisconsin
speaking of refrigerators, can anyone tell me why our '07 safari's fridge freezes eggs when on shore power?
LINDAMART is offline   Reply With Quote
Old 05-22-2015, 06:40 AM   #24
Skater's Avatar
1995 30' Excella
Bowie , Maryland
What are people using as a connector between the tow vehicle and the trailer to carry the larger amount of power?
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 05-22-2015, 10:31 AM   #25
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I don't have mine set up as a separate circuit. But if I was I would use the Anderson Powerpole connectors. I have built a couple of extension cables for my portable solar panels using them.
Aaron
WBCCI #XXXX AIR #2495
Old 05-22-2015, 11:24 PM   #26
Corvallis , Oregon
I am using a 4 pronged receptacle and matching outlet using 2 of the connections for supplying 12 vdc to a relay controlled by a 110 vac circuit (not the refrigerator circuit.)
Old 05-23-2015, 12:14 AM   #27
Man, I'm glad I asked for thoughts on this... there is a lot to dig into here! Thank you.
Old 05-23-2015, 08:53 AM   #28
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
Thumbs up Frig. on Propane
Thanks all, Still getting use to Land travel and need all the good advice I can get.
Old sailor need all the help I can get.
dames7 is offline   Reply With Quote
DC to AC inverter for fridge while driving the ponz Refrigerators 20 03-14-2015 05:35 PM
inverter to power fridge while driving? duggie Batteries, Univolts, Converters & Inverters 39 01-24-2015 06:28 PM
A/C switch for dash, run genset while driving? Bella123 Electrical - Systems, Generators, Batteries & Solar 4 09-17-2014 10:17 PM
Inverter to run refer while driving... lilynhoward Batteries, Univolts, Converters & Inverters 26 11-21-2010 03:06 PM
Fridge While Driving Chaplain Kent General Motorhome Topics 18 08-22-2005 01:29 PM
