Old 10-16-2008, 08:55 PM   #1
Whizzo's Avatar
2014 23' FB Flying Cloud
San Antonio , Texas
Images: 18
'Revving' Converter
On our first weeklong trip, the converter (WFCO WF-8900 series, 3 stage) starting making a higher-pitched sound like a small engine being constantly revved. It would go on for a few minutes, then stop. From what little I could get from the manual, it may be having trouble switching between modes?
I tried cycling all the breakers, unplugging the 7-pin from the truck (since we were hitched up to depart early), and then tried shutting off a light. It stopped. It seems if I switch on one too many lights, the noise returns. So I figure a certain amount of current load is the trigger.
Anyone seen this before? Simple fix, or does it sound like a warranty service visit for the converter?
2014 Flying Cloud 23FB
2015 Ram 1500 EcoDiesel
Whizzo is offline   Reply With Quote
Old 10-16-2008, 09:05 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
It could be the cooling fan in the converter. It should only come on when the unit is hot and putting it under a load might cause it to cycle on.
Richard
Old 10-17-2008, 08:23 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Our Intellipower does that. It is the cooling fan inside the unit, and is completely normal. Providing, of course, our revving sound and your revving sound are the same thing.
Old 10-17-2008, 09:09 AM   #4
just jd.
5cats's Avatar
2007 20' Safari SE
San Diego , California
I agree. Bet it's just the bearing in the cooling fan itself.
If you don't want to put up with the noise, it might be surprisingly simple to open it up (power/batteries disconnected, of course) and pull just the fan, then take it to someplace like Fry's to match up a replacement. An hour + a few bucks and you're good to go.
Or, you could give Randy a call at bestconverter.com, for a better diagnosis.
Cheers,
-jd.
2007 20' Safari SE/LS // 12063 //CA-5// ("ex") 2916
5cats is offline   Reply With Quote
Old 10-19-2008, 03:27 PM   #5
New Borockton , Alabama
Images: 21
WFCO uses a load controlled cooling fan. I guess it does sound like a small electric motor revving but they all do quite frankly. As long as it doesn't sound like a squeal or binding, its probably normal.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 10-19-2008, 06:57 PM   #6
Whizzo's Avatar
San Antonio , Texas
Images: 18
I appreciate all the insightful replies. I guess the irregularity of the noise is what bothered me. But it has not come back since the first night we noticed it. I wonder if it might also have been temperature-related, as it was our first cold night/below freezing?
Old 10-19-2008, 08:16 PM   #7
Images: 21
Hi Whizzo, yes it probably was because the furnace fan is the largest consumer of DC power after battery charging and combined, it will work the heck out of your converter. I left out the fridge and that is also a battery destroyer while on DC so if you have a 3 way fridge, keep that in mind.
converter, noise
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 19 02-08-2010 10:05 PM
What to do with old converter? msmst25 Batteries, Univolts, Converters & Inverters 11 06-15-2008 03:32 PM
What is the best converter? jdalrymple Batteries, Univolts, Converters & Inverters 2 03-19-2008 01:42 PM
Where's the converter? gparker Batteries, Univolts, Converters & Inverters 4 08-24-2007 03:30 AM
Need Some Help - converter jjohnjr Interior Restoration Forum 0 08-23-2006 06:21 PM
