Old 06-07-2009, 06:08 AM   #1
2004 25' Safari
brighton , Ontario
require new batteries
Preowned--25' safari---will be parked in a florida rv park all winter--do NO dry camping--use batteries for jacking trailer to set on ball-----have 2 deep cycle batteries that require replacement --is it necessary to replace with expensive deep cycle batteries--any battery suggestions???
Thanks Steve
presquille is offline   Reply With Quote
Old 06-07-2009, 06:22 AM   #2
RBolton's Avatar
Belington , West Virginia
Originally Posted by presquille View Post
--is it necessary to replace with expensive deep cycle batteries--???
NO, but... Battery life may/will become an issue if you fail to keep a full charge on a non-deep cycle battery. A standard auto battey is not meant to be run down and recharged over and over. Also a good dependable auto battery is not cheap either.
Roger
RBolton is offline   Reply With Quote
Old 06-07-2009, 07:49 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If that is all you use the battery for any battery will do, in fact you can probably scale back to one battery.
But, unless you have a battery disconnect switch there are certain parasitic draws that run off the battery 24/7/365. For example the radio and I think the circuit board in the refridgerator and furnace.
It will decease battery life to fully discharge.
New Batteries woodedareas Batteries, Univolts, Converters & Inverters 3 03-09-2009 08:43 AM
Batteries SJ Brown Batteries, Univolts, Converters & Inverters 9 06-17-2008 05:59 PM
What states require RVs to scale at truck inspections? 3 Dog Nite On The Road... 25 11-12-2007 09:33 AM
batteries dsmith Electrical - Systems, Generators, Batteries & Solar 7 03-15-2006 07:36 AM
Batteries 85/345 Mechanics Corner - Engines, Transmission & More... 30 01-28-2005 04:47 PM
