Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 08-19-2002, 12:53 PM   #1
Les Gilliam
Les Gilliam's Avatar
Profile:
Replacing wire harness
I have recently purchased a 1998 Excella 28 and need to replace the wire harness that leads from the Airstream to the tow vehicle. I have located all the connections inside the trailer and have the wiring diagram. I think I can make make all the new connections OK, but want to make sure there are no hidden pitfalls before I begin. Also, does anyone have any recommendatioons for a source for the wiring harness?
Thanks for any help you can give me.
Les
Les Gilliam is offline   Reply With Quote
Old 08-19-2002, 01:58 PM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Les,
Usally when the time comes to make a new harness most folks just buy the ends that match the tow vehicle and the trailer. RV places usally have the ends as well as the bulk wire. Then it is just a matter of assembly. RV places will do it for you but there would be a labor fee involved.
Short answer is it is custom based on the trailer/vehicle.
The way you describe it, it sounds like your harness directly connects to the trailer??? Usally there is a socket style connector on the front of the trailer.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 08-19-2002, 02:20 PM   #3
FrankR
Profile:
Suggestions for new wiring
I would suggest that care is used to select materials for project. A wire called mtw, read machine tool wire, is terrific for most wiring, and is tranded. This wire is very common and available at most electrical stores and sign companys. The wiring from tow vehicle is not a long distance and Number 12 AWG will do a good job. If possible, after check to be assured all connections are correct, soldering is very good. The connections inside the quick electrical disconnect should have all the wire ends soldered before fastening with screw. The new can wire sleeving is good instead of lots of plastic tape to make a wire bundle for plug end. It is not necessary but different wire colors for different tasks is nice. Extra wire can be made into nice spare wire roll in trailer. Making a mechanical restraint for wire is required. Usually the ground wire will do this task well. I usually size the ground wire to # 8 AWG MTW with the ends crimped and soldered.
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 08-19-2002, 05:39 PM   #4
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
with that new of a trailer i would go right to airstream for the harness.
that way you will get the moulded plug that is impervious to moisture.
the other end goes to the terminal block in the front of the trailer.
john
Old 08-19-2002, 09:25 PM   #5
Les Gilliam
Profile:
My thanks to all who answered my question relative to replacing wire harness on the trailer. My Airstream must have been modified at sometime in its life because it does not have a plug in socket at the front of the trailer. The wires go up through the floor and into the same area with the converter, where they are spliced into other wires that lead to the lights, break, etc.
I have a call into Airstream technical support, so maybe I can find more information from them. Thanks again to everyone who responded. You have been a great help.
Les
Les
loose wire whistler Electrical - Systems, Generators, Batteries & Solar 6 02-21-2004 04:50 PM
silver wire? markus Electrical - Systems, Generators, Batteries & Solar 3 12-21-2003 02:19 PM
replacing glass fuses with blades maznblu Electrical - Systems, Generators, Batteries & Solar 4 08-06-2003 12:34 AM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 12:09 PM
HOT Topic for the summer-Air conditioners-Best/worst? thenewkid64 Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-03-2002 05:55 AM
