04-16-2015, 04:24 PM
1976 27' Overlander
Solvang
Replacing UniVolt with ProgressivevDynamics
Hello and thanks in advance for any help. I am replacing the UniVolt power unit with the PD 9200 in my 1976 Globetrotter. Thus far everything's is working with the exception of the Power On light in the Control Panel. The UniVolt has a 3rd white wire to connect to the fuse panel for that circuit. The PD 9200 does not. Where do I connect a jumper to complete that circuit so that the light is on when city power is connected?
Cheers, John in Solvang, Ca.
04-16-2015, 05:26 PM
1988 25' Excella
Trumbull
, Connecticut
Power On Light
Hello Mogfrog. If you do a search on this forum and ask for info on "power on light" you will get all the info you need. When I did my 88 I had the same problem and the fix is dificult so I just pluged an LED night light into a 115VAC receptical and that will illuminate when connected to shore power.
Happy camping nm1oqrz
04-16-2015, 05:59 PM
1976 27' Overlander
Solvang
Thank you nm1oqrz
Yeah, Im embarrassed to say that I did not use the quotes in my search. Good info there after new search. I like your approach. Just happen to have an LED night light. Cheers. John Wright
04-16-2015, 06:05 PM
1976 31' Sovereign
Oswego
power on light
Dittto using led nite light w/out any mods.
04-17-2015, 02:31 PM
Gazoo!
1963 19' Globetrotter
Denver
Having a '63 GT that doesn't have a Univolt, i'm faced with installing a power unit such as the PD-9200 unit 45amps. Question I have is wrt the 12v circuit display panel that I'll also want to install. any advice is appreciated in this regard for which system is appropriate.
Thanks!
Gazoo
04-17-2015, 04:58 PM
1973 Argosy 26
1966 30' Sovereign
Southern
, Wisconsin
Thanks!
Gazoo
Sweneau. I hope I'm understanding your question correctly and answering correctly.
With the PD 9245, you'll need a separate 12V fuse block to connect your positive output from your converter. I also placed battery input at the same point (with a circuit breaker from the battery). Then use an auxilliary grounding lug for the neg./ground side of the converter and the battery side negative. Unless your distribution panel has these integrated (mine didn't).
All that is gold does not always glitter...those who wander not always are lost....
04-17-2015, 06:47 PM
1967 26' Overlander
Spartanburg
, South Carolina
Replaced orig. Univolt in our 67 Overlander 8 yrs ago with a PD9130R which failed under warranty. PD replaced it promptly at no cost to me. Knock on wood, still working well with an 8 yr old Optima battery.
04-18-2015, 10:09 AM
Gazoo!
Denver
mnmhays,
Thanks for reply and advice. Understand fully the wiring setup you describe. Wondering though, i'm used to seeing in older trailer setups (not AS) the power unit being visible (flush with wood framing) and having shore power tied into it there as a central unit. Circuit breaker for 120v feed and circuit breaker for 12vdc input/output. I'm gathering that I need to put a kit together then?
Thanks!
04-18-2015, 10:27 AM
1973 Argosy 26
1966 30' Sovereign
Southern
, Wisconsin
mnmhays,
Thanks!
In mine, there is a breaker box with 120v shore power coming in to it. I only have 1 breaker (but space for another) because I have no air conditioner. From the 120V breaker box wires are run to feed 120v outlets in the TT. My original setup with the Univolt had 3 strand romex wired into the univolt. The PD9245 has a standard plug on it, so I wired an outlet and secured it to the wall. My converter sits on the floor of the bathroom closet. I will have a hinged panel over it to allow access. It goes without saying...make sure everything is grounded well.
04-18-2015, 12:21 PM
1974 Argosy 20
Kooskia
, Idaho
The power on light on Airstreams was fed from a special Univolt exclusive system, and is not easy to duplicate with a modern converter/charger. It can be done, but is realy not worth the effort, other than with a museum quality restoration. And if doing a museum quality restoration, you want an original Univolt anyway. That is about all they are good for these days.
Just don't connect the power on light wire to anything when doing the conversion, and if yu want to see if power is on, use a little neon night light plugged into one of the 120 volt outlets in the rig.
04-19-2015, 11:48 AM
1976 31' Sovereign
Oswego
Converter
Putting on floor in box covering with lid cuts ventilation as they need air, have fans built in to cool. In my opinion you will fry it from heat also I believe install directions state so many inches all around so it can breathe. I have Intelapower & powermax both state clearance. I may have both names of these 2 mixed, still same specs.
04-19-2015, 11:56 AM
1973 Argosy 26
1966 30' Sovereign
Southern
, Wisconsin
I suppose that I should have been a little clearer on my placement of the converter. The hinged panel is the closet shelf bottom, per the original design. My converter is mounted similarly to the original univolt's placement. The "box" is effectively a 30"w X 20"d X 16"h space at the bottom of the bathroom closet.
05-31-2015, 04:35 PM
1974 23' Safari
Sacramento
hi there...any experience with old blue and white wires from TT and uni volt system (blue panel w/ glass fuses)...I have new pd4045 and want to make sure I connect these to the correct location...
05-31-2015, 04:38 PM
1974 23' Safari
Sacramento
QQ....where do the blue and white wires (heavy gauge previously connected to uni volt panel) connect on new converter/panel etc.?
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
To Univolt or NOT Univolt?
aircooled4 |
Batteries, Univolts, Converters & Inverters |
11 |
05-13-2012 07:20 PM |
Replacing my Univolt in my 1965 Caravel
toastie |
Electrical - Systems, Generators, Batteries & Solar |
10 |
04-29-2008 07:55 PM |
Replacing a Univolt in a 31' International
wacnstac |
9 |
09-07-2006 09:39 AM |
Replacing Univolt and old line/battery switchbox this weekend
JMoy |
1 |
08-23-2006 06:24 PM |
Replacing Univolt and 12V confusion
sander17 |
8 |
06-29-2004 09:09 AM |
