Old 06-07-2018, 09:31 AM   #1
2018 30' Flying Cloud
Gig Harbor , Washington
Replacing Interstate 12 volts with 2 Fullriver 6 volt AGM's Question
Hi All,
I know there is quite a bit of information on replacing the factory 12 volt interstate's with 2 6 volts in a series. I get the connection between the new batteries to make them a series. I have 2 positive and 2 negatives coming from the 2018 30' Flying Cloud (attached drawing). And my question is do I connect the 2 positive so the free positive with ground cable and the 2 negatives to the free negative? Don't want to damage the new batteries.
hoagy_007 is offline   Reply With Quote
Old 06-07-2018, 09:33 AM   #2
Image associated with question.
Old 06-07-2018, 04:33 PM   #3
2011 22' Sport
Portland , Oregon
1 pair likely goes to the normal trailer 12V system and the other pair is probably dedicated for your inverter, though I am not remotely an expert on how they do things in the larger FCs. You would likely need to connect them both to the open negative/positive battery terminals.
SilverHouseDreams is offline   Reply With Quote
Old 06-07-2018, 05:13 PM   #4
Thanks, that is what I'm going to connect up this evening. I spoke to the dealer that uses Fullriver (not that brand is all that important) and will connect up the positive to positive and negatives to negatives. Makes sense!
Old 06-07-2018, 08:40 PM   #5
waninae39's Avatar
2017 22' Sport
NCR , Ontario
IMHO, go LiON
smaller, lighter and more usable capacity.
over the battery lifetime the Capex and Opex is lower
waninae39 is offline   Reply With Quote
Old 06-08-2018, 03:42 PM   #6
zapper's Avatar
2007 25' Safari FB SE
2017 30' Flying Cloud
Highland , California
Originally Posted by hoagy_007 View Post
Hi All,
I plan to do the same conversion on my 2017 30' FC. Suggest you take a photo of existing wiring system in the bat. box as is, before you upgrade so you can reference what was positive and negative before. I noticed that some black color coded wires actually go to the positive battery pole rather than the negative. Go figure.
zapper is offline   Reply With Quote
Old 07-07-2018, 05:13 PM   #7
Vantair
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
Also Replacing Interstate 12 volts with 2 Fullriver 6 volt 220ah AGM's
Coincidence after much AGM battery and size searching did the PD4655vl (per Randy) retrofit and this weekend this “exact series battery upgrade”.
2) Fullriver DC220-6 (6volt 220ah group 27 AGM) 71lbs ea. 2 yr warranty and 7 yr adjusted.
Also, because NO PRE 2017 BATTERY BOX EXTENSION MOD NEEDED for these 2) group 27 220ah bad boys!
These particular batteries height to top of flat terminal are a slick 8.9” tall 12volt factory Interstates are 9.5” (will be adding Fullrivers superior brass screw in AP stud terminals keeping original AS factory auto lug connections).
Excited to get some now serious boondocking as these AGMs are reported spec underrated (outperform printed specs) and can really take deep discharge abuse.
Vantair is offline   Reply With Quote
Old 07-07-2018, 05:27 PM   #8
van guru
1994 28' Excella
Hood River , Oregon
OP,
Presuming your original batteries were 12V then each pair of + and - cables were likely connected to each of the two batteries. My guess is that the two sets of cables come together at the other end. Easy enough to check that before proceeding.
Or, as stated, one set supplies trailer 12V and the other the inverter.
So now that you have two 6 volt batteries with the series jumper between them you essentially have one 12V battery. To carry the full capacity you need both sets of cables connected. So as you have stated; both + cables to the open + battery terminal and both - cables to the open - terminal. We often recommend a terminal fuse on the + battery connection. Bluesea makes them.
Check the other end first and be aware that although I understand electrics, I am not familiar with your particular AS.
Full River does make a 12V AGM in group 27 size. They are great batteries. We have them in our vans.
All the best,
Hein
Hein is offline   Reply With Quote
Old 05-13-2019, 02:07 PM   #9
2014 25' FB Flying Cloud
Grand Rapids , Michigan
I know I’m bumping an old thread here but we are ready to pull the trigger on a pair of 220-6s as well. We have a 2014 vintage box so know we will need to do some work to make them fit.
My question is what are folks using for the terminals to accommodate both the car connection and the ring connections? Pictures would be great.
Thanks!
MIFC is offline   Reply With Quote
Old 05-13-2019, 04:30 PM   #10
steverino's Avatar
2018 30' Classic
Ivins , Utah
Images: 8
I cut off the old automotive style post clamps and crimped on ring connectors. This is an install of 2 banks of DC220-6, with one bank in the battery box, and the second under the couch.
steverino is offline   Reply With Quote
Old 05-13-2019, 06:32 PM   #11
Thanks for the quick reply!
Old 05-16-2019, 07:53 AM   #12
Vantair
Vantair's Avatar
Fullriver Brass Lug Adaptors
On our 2005 didn’t want to “cut” any factory harness terminals keep flexibility to revert to standard lug batts in emergency or deal with reattaching something aftermarket even more bulky.
Therefore used Fullriver provided impressive “brass” screw in lugs terminals to maintain original harness use. POS post terminal being intentionally slightly larger than the NEG terminal to avoid reversing cables . Left tight but adequate space under lid using rubber covers to insulate.
Old 05-16-2019, 07:59 AM   #13
Vantair
Vantair's Avatar
Pics of brass posts
Fullriver brass posts. (Temp reuse of 2 factory black/red series jumpers until larger gauge black single jumper arrives).
ID:	340871   Click image for larger version
Old 05-16-2019, 12:52 PM   #14
Thanks for your response and the pictures!
We’re finding that the use of the brass posts provided plus the screw on top of that to hold the ring terminals puts us at 10 1/4 inches high, and the depth of our box is only 10”. If we went all ring terminals we might be able to make it.
The trailer is still in storage; we’ll need to get it home in the next week or so and size it all up.
12 volt
Any experience with Fullriver batteries? jpons Batteries, Univolts, Converters & Inverters 19 03-12-2019 05:39 PM
12 Volt or 6 Vollt Batteries or AGM's dames7 Batteries, Univolts, Converters & Inverters 20 07-22-2016 08:42 AM
Two 6 volt batteries replacing one 12 volt TY PECK Electrical - Systems, Generators, Batteries & Solar 2 11-12-2015 12:22 PM
Battery AGM (4) 6V GC2 vs (2) AGM 8D Torpedo Family Land Yacht/Legacy Motorhomes 3 11-15-2012 05:35 PM
1 of 3-12 volt sockets getting only 12.16 volts? squashy Electrical - Systems, Generators, Batteries & Solar 2 08-29-2011 07:48 PM
