11-03-2014, 01:19 PM
Mandeville
, Alabama
Replacing Converter
Anyone familiar with this converter?
Just placed an order from Randy at Best Converter
11-03-2014, 01:28 PM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
Not familiar with that model, but the three that I have are Progressive Dynamics brand and I am well pleased with them. I have 2 9245's and 1 9260.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
11-03-2014, 01:57 PM
Mandeville
, Alabama
This is a kit to replace the Parallax 7355!
11-03-2014, 02:43 PM
2007 28' International CCD
Springfield
, Missouri
This is the one I installed and it works great.
Magnetek/Parallax 6300/7300 Upgrade Kit
11-03-2014, 02:52 PM
Mandeville
, Alabama
Thanks!
11-03-2014, 03:49 PM
2010 28' Flying Cloud
Lower Alabama
, USA
Natty,
This is a great upgrade and a great place to buy it. Randy is "Johnny on the spot" and is very helpful.
Lots of folks have bought from him and updated the Parallax with kit. If you search here you will find several threads. Here are a couple to help you get started.
http://www.airforums.com/forums/f516...fc-126477.html
http://www.airforums.com/forums/f449...ge-126268.html
Good luck with the install.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
11-03-2014, 04:10 PM
Mandeville
, Alabama
Alphonse,
That is exactly what I was looking for, thank you so much for the help! This is my first post of many more, I'm sure.
The pictures are going to be very useful when I install!
11-03-2014, 04:30 PM
Lower Alabama
, USA
Natty,
You are welcome!
Welcome to the Forum!
Which model/year trailer are you installing this in?
Alan
Air #64439
11-03-2014, 04:55 PM
Mandeville
, Alabama
2006 Safari 27' I just bought it two weeks ago from a friend of mine, it's like brand-new couldn't pass it up! We spent the first week camping out at our local park and loved it!
11-03-2014, 08:21 PM
New Borockton
, Alabama
You will love the upgrade! I have to laugh at your handle, Natty Lite. I used to drink Miller Lite until recently. With two kids in college, Natty works
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
11-03-2014, 09:22 PM
2007 25' Safari FB SE
North/East
, New Jersey
Natty Lite.... I had to replace mine when we were in Florida this past winter. The hardest job was hooking up the 12v supply feeds to the DC section of the deivice. The original feeds came into the bottom of the board with fuses. The new feeds have to come up behind the board and do a 180 over the top of the board and into the connectors. Hopefully Airstream left enough spare 12v supply wire behind the unit that you can pull in to make the turn behind the board. There was a wire connector that I believe was on the 120 v side of the unit that did not come with the new unit and I had to remove it from the old unit and splice it in. I've been very happy with the new unit. The original unit's cooling fan came on whenever I turned on the ceiling lights in the aft section of the trailer. This unit must run much cooler as I have never heard the fans running.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
11-03-2014, 10:36 PM
1999 34' Excella
Hillsboro
Had our original 1999 go up in smoke one day when we switched things 'on' ... pretty freaky seeing the smoke curl up from beneath the Gaucho...
Not long after install, our replacement Progressive quit charging. We had to deal with the manufacturer for warranty resolution.. so, I was without the converter for 10 days.. from my failure, to receiving and install of replacement.
So far.. bullet proof... until I guess the right 'bullet' hits it...but, that is just the nature of man made stuff...
BTW, the charge rate and output varies according to 'need' quite nicely. I can tell the voltage output by watching my 12VDC monitor... 13.4 steady to 13.2... just rocks along.. You should notice better stability in the 12VDC lighting.
Peace and Blessings..
Channing
WBCCI# 30676
11-04-2014, 04:21 AM
Mandeville
, Alabama
Hey guys, thanks a lot for the information. I will be doing the install next week. I might get back with ya'll!
Yes, the name of my airstream is the Natty Light! It was a joke around the campfire and It just stuck! I'm more of a microbrew kind of dude!
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Converter fuse blowing (new converter)
wannaroam |
Batteries, Univolts, Converters & Inverters |
28 |
07-06-2015 02:39 PM |
Replacing a missing converter
My66Dino |
5 |
10-21-2014 09:14 PM |
Univolt 45 amp converter to a 30 amp converter
scooterbug76 |
15 |
02-24-2013 02:59 PM |
Replacing Parallax converter with Xantrex Inverter/Charger
worksology |
22 |
01-22-2011 08:59 PM |
Converter box for into floor mount
FrankR |
Electrical - Systems, Generators, Batteries & Solar |
0 |
03-15-2002 09:49 PM |
